No start after some minor installs
Old Apr 29, 2007 | 02:30 AM
idriveanevo's Avatar
Originally Posted by g63tawd
Yeah it cranks and just doesn't turn over. I forgot but i did get it running on the sunshine in a can (starting fluid) and ran fine on that.
= no fuel.... something wasnt put on or is missing from the pump, like a rubber seal?? im sure you now what the pump sounds like? make sure its running
Old Apr 29, 2007 | 02:33 AM
subrwho's Avatar
it has to be something to do with the fuel system. . one thing, when you pulled the stock pump out as you were pulling it out are you sure you didnt yank a little hard and accidently diconnect one of the wires that goes to the harness that connects on to the fuel pump? (thats actually happend to alot of people)
Old Apr 29, 2007 | 02:37 AM
g63tawd's Avatar
No there is power to th pump but like I said there is fuel th the feed side of the rail but out of the regulator there is nothing. I know that the pump is working and getting to the rail but what I don't understand is why there is no fuel returning to the tank. When I pull the line after the regulator there is no fuel there.
Old Apr 29, 2007 | 02:40 AM
subrwho's Avatar
wow this is really odd. . . so you didn't mess with anything that has to do with the fuel system besides the fuel pump right? So absolutly nothing regarding fuel was touched under the hood until the problem started right?
Old Apr 29, 2007 | 02:41 AM
subrwho's Avatar
are you 100% sure that fuel is getting to the rail and thats not just left over fuel that was in the lines?
Old Apr 29, 2007 | 02:44 AM
g63tawd's Avatar
No nothing else thats why I assumed the pump but when I put it back to stock it still did it. But I can't think of anything electrical that could have to do with it obviously I remove the oxygen sensor but I know that is all hooked up again. I can't figure this out for the life of me.
Old Apr 29, 2007 | 02:46 AM
g63tawd's Avatar
Yeah postive it is getting to the rail because it isn't thereat first but when you pull the line after it pumps it starts to flow out of the line.
Old Apr 29, 2007 | 02:48 AM
subrwho's Avatar
you said its not the pump, but I still say its something to do with the harness that plugs into the pump. . check those wires and make sure it didnt come out of the connector or come loose. . because it seems like thats what your problem is. .
Old Apr 29, 2007 | 02:49 AM
g63tawd's Avatar
I checked those plugs It is secure and you hear the pump run
subrwho's Avatar
you said it ran when you used starter fluid right? how long did it run for? did it kill out or did you shut the car off?
Old Apr 29, 2007 | 02:55 AM
g63tawd's Avatar
It ran until the starting fluid was all used
Old Apr 29, 2007 | 02:58 AM
subrwho's Avatar
this just doesnt make sense! hmm give me a second to think. im tryin to help all I can
Old Apr 29, 2007 | 03:00 AM
striderx88's Avatar
working now?
g63tawd's Avatar
i appreciate it i have spent the last 5 or 6 hours trying to figure this out and I know it is gonna be something dumb because it always is.
Old Apr 29, 2007 | 03:04 AM
subrwho's Avatar
ya I hate when **** like this happens to my car. So it gets all the way to the regulator but thats as far as the fuel will get?
