No start after some minor installs
Old Apr 29, 2007 | 01:27 AM
g63tawd's Avatar
Unhappy No start after some minor installs
So just finished up installing a header, O2 housing, Greddy full auto TT, walbro fuel pump and an AMS LICP. Now after everything was done tested turbo timer with just the key in the on position, dropped the e-brake and the timer shut off. Buttoned loose ends up and get in to crank it and she doesn't start. So first thing I check is the fuel pump getting fuel to the rail but doesn't get past the pressure regulator. Then unplugged the TT thinking it was messing with the anti theft and no luck there either. Car has spark and also checked the immoblizer code and that is still the same as before. So hopefully someone has an idea of what the hell is going on. I think I have told you everything that I know up to this point. Also no engine lights are on so please offer suggestions I need them. Thanks
Old Apr 29, 2007 | 01:31 AM
DontRevMe's Avatar
I havent installed a TT, but do they interrupt any ignition harness wires?..
Old Apr 29, 2007 | 01:33 AM
idriveanevo's Avatar
it cranks but no start?
Old Apr 29, 2007 | 01:46 AM
g63tawd's Avatar
I bought the plug and play harness and it is a jumper between the ignition harness and taps the wires need for the timer. The car cranks and thats about it.
Old Apr 29, 2007 | 01:49 AM
i would say maybe you bent or broke a pin on the ignition when u put the p&p harness on but you said it IS getting spark? how did you check that its getting spark?
Old Apr 29, 2007 | 01:51 AM
DontRevMe's Avatar
if its cranking then its not the TT..
Old Apr 29, 2007 | 01:54 AM
g63tawd's Avatar
Checked the ignition the old fashion way of screw driver in plug boot and letting it arc. And she is sparking. Yeah I figured it wasn't the timer but I thought i mine as well eliminate one thing at a time.
Old Apr 29, 2007 | 01:57 AM
DontRevMe's Avatar
can you hear the fuel pump?
Old Apr 29, 2007 | 01:58 AM
g63tawd's Avatar
Yeah you can hear the pump whine also chaged it back to stock pump and then back to the walbro.
Old Apr 29, 2007 | 02:06 AM
subrwho's Avatar
this may sound dumb but its worth a shot. . unplug the negative battery cable for ten minuted and press the gas pedal twice then re-connect it. . its worth a shot. .
Old Apr 29, 2007 | 02:08 AM
if it cranks, and your gettin spark, it must not be getting fuel. you hear the pump but is it installed right? if you changed back i would think its right but thats all thats left...
Old Apr 29, 2007 | 02:18 AM
g63tawd's Avatar
I unhooked the battery for about 15 minutes but please excuse my ignorance what does hitting the throttle twice do? I am getting fuel all the way to the pressure regulator. I pulled the regulator and fuel leaked out, rebolted the regulator and then unhooked the rubber return line from the regulator to the metal line that runs back to the drivers side and get no fuel running out there at all. So it stops at the regulator and doesn't get past there far as I can tell.
Old Apr 29, 2007 | 02:24 AM
subrwho's Avatar
So it will crank right? does it just keep clicking?
Old Apr 29, 2007 | 02:27 AM
you know for sure your getting spark, and the only other thing you changed was the fuel pump and as you know the other part you need is fuel...
g63tawd's Avatar
Yeah it cranks and just doesn't turn over. I forgot but i did get it running on the sunshine in a can (starting fluid) and ran fine on that.
