Custom Turbo by FAT
Old May 15, 2007 | 10:44 AM
  #61
Slow Evo's Avatar
Originally Posted by StyleFront
gt4088?
No, it is a Hybrid 37r
  #62
nutrulz's Avatar
That's a pretty slick looking set up, can't wait to see numbers.
Old Jul 13, 2007 | 12:05 PM
  #63
blueG60rado's Avatar
*still waiting for dyno and track results*
Old Jul 13, 2007 | 12:11 PM
  #64
theblue's Avatar
I was very skeptical and curious about this car also after reading about it a while back....
tuners don't tend to post bad news until they've fixed it... if they don't fix it they don't post.
Old Jul 13, 2007 | 03:26 PM
  #65
precisi0n's Avatar
from what i *heard* its pretty bad...
Old Jul 13, 2007 | 03:36 PM
  #66
sikrsix's Avatar
So did you even attempt the "maf" blow thru?
Old Nov 4, 2007 | 10:06 AM
  #67
Truedsmer's Avatar
so what happened with this car? i never heard anything about numbers
Old Nov 4, 2007 | 10:18 AM
  #68
20Grockit's Avatar
awesome looking setup and huge turbo. i would be a little concerned about the heat issue as mentioned earlier. just curious but how much money have you invested in that setup???
Old Nov 4, 2007 | 12:14 PM
  #69
jimbobdaga's Avatar
Very nice, but it looks like you should have just went with a GM blow through maf instead of that crazy L shaped MAF adapter. That's just me though.
The manifold is sexy.
Old Nov 4, 2007 | 12:42 PM
  #70
scorke's Avatar
I cannot wait to see the radiator-water pump hose.....
Scorke
Old Nov 4, 2007 | 01:34 PM
  #71
discopotato03's Avatar
Actually its a T04Z with apparently a 0.84 A/R TS T4 flanged turbine housing . Nothing 37 about it .
Arguably the turbine housing A/R could have been a little larger because functional TS systems are less A/R sensitive than single scroll ones . Its debatable if a smallish TS housing will pull it up to speed any sooner than a larger one but highly likely to be restrictive at higher engine revs .
I think the outcome would be that the engine will run the turbine housing out of flow before the compressor and its housing does .
Yes I thought of the SR20 manifold in that other pic too , I think Nissan Performance Mag (online) has an article about it under "Project SE/R - the turbo" .
That one had a fair bit of bracing near the turbo to support its weight .
Be interesting to see the FAT system results , cheers A .
XcreatonX
Aug 23, 2010 05:54 AM
hytek369
For Sale - Wheels / Tires
10
Nov 8, 2008 08:27 PM
Sam@DriveLine
Sep 3, 2008 10:32 AM
import_speedzz
Jan 27, 2006 11:12 PM
