[Test] Why Revolvers are hit or Miss....
Old May 1, 2007 | 10:09 PM
Noogles's Avatar
Cam doctor is a a machine that measures the lobes on the cam for lift, icl, lsa and pretty much any other measurement you want.
Most Race Engine Builders will have one.
Old May 2, 2007 | 10:46 AM
Aby@MIL.SPEC's Avatar
Originally Posted by Noogles
Install height was set a 30.6mm
All springs where tested to 13mm coil bind at 11.4
i am reading that you tested the open/full spring pressure with 13mm of lift, but coil bind was achieved with 11.4mm lift
you tested @ 11.4mm?
coil bind @ 13.0mm?
Old May 2, 2007 | 12:44 PM
trinydex's Avatar
Originally Posted by Exciting News
Good luck with that. The manufacturer up and vanished like a fart in the wind.
Noogles, while I commend you for the test, I wonder how many people actually used the springs supplied by Revolver? If they're still "hit or miss" without that variable then what? Pd1 is the most infamous example of Revolvers not wanting to play nice. I don't remember if he used their springs in the first place. Nevertheless, solid work.
I wish you could throw some Tomei 260/270/280 Procams on the cam doctor. A little birdie told me that Revolvers, Pipers, and Tomeis share DNA...
as in they're the same?
Old May 2, 2007 | 01:18 PM
Exciting News's Avatar
More so the other 2 being modeled after the Tomeis.
In truth, I wouldn't mind getting my mitts on a pair of Piper's UR cams. A few people on lancerregister love them as they seem to give a beefy midrange. It seems those UK boys have a few cool toys that we just don't get over here. The cost is just too prohibitive.
Case in point:
This Sucker
They must like quick spool and torque in the UK. I wonder how this would compare to the FP Green?
Old May 2, 2007 | 01:35 PM
Noogles's Avatar
coil bind @ 13.0mm?
I listed the compressed height.
i would have needed to compress another 1.6mm to get to coil bind
Old May 2, 2007 | 01:38 PM
trinydex's Avatar
Case in point:
This Sucker
i hear that sucker surges quite a bit.
Old May 2, 2007 | 01:40 PM
Noogles's Avatar
Case in point:
This Sucker
I'm waiting to get a set of my piper Drag cams From Dentist mapped,
Old May 2, 2007 | 03:43 PM
Pd1's Avatar
Pd1
Yep. I was using the Revolver springs/retainers on my VIII when I had these cams installed.
Thanks for posting this data. It supports the theory of questionable quality control on Revolver products.
I wonder if this mismatched spring pressure issue has anything to do with the noise that many people hear coming from the valvetrain when the cams are set to 0/0 (and which goes away when the cams are retarded).
Old May 2, 2007 | 03:45 PM
trinydex's Avatar
i just don't understand that occurance wtih the revolvers... something is totally wrong. someone find out exactly what it is.
Old May 2, 2007 | 04:00 PM
Erik@MIL.SPEC's Avatar
This is the kind of empirical data I was getting at when I questioned HOW and WHY your cams did that.
Old May 2, 2007 | 07:47 PM
What are you doing with these cams after you're through with them? I bet my dual spring titanium setup could handle those pesky revolvers. hint hint
Old May 3, 2007 | 08:13 AM
Noogles's Avatar
Not as well as my custom set of "PSI" H13 Tool Steel beehive Spings, "Si" Tiatnium intake valves & retainers
I might sell them, i might just keep them for some more R&D
Old Jul 4, 2007 | 06:38 PM
CT-PR_Evo8's Avatar
Sorry for reviving this thread.
So if the problem is the springs and retainers ,another set of another brand with the same specs as the advertised for these springs would work and solve the problem?
Old Jul 4, 2007 | 06:46 PM
EvoDan2004's Avatar
i have revolvers. with supertech dual valve springs and ti retainers.
sean ivey tuned my car
375hp/380trq
93 oct
stock ecu.
24psi
11.2/3 afr's
how do i know if my cams are good or crap???????
Old Jul 4, 2007 | 08:34 PM
Ted B's Avatar
I would recomend everyone have the springs tested before they are installed to see what you are getting. Improper Spring Pressures will kill power!
Given the aggressive ramps of those cams, I doubt they will tolerate anything less than full-on-spec springs. Springs that don't keep valvetrain action true will reduce power (among other things).
