Shimming supertech dual valve springs???
Old May 2, 2007 | 08:37 AM
Steve@NoLimitmotors's Avatar
Does anyone know if supertech dual valve springs need to be shimmed to rev over 9000 rpm???
Old May 2, 2007 | 08:55 AM
nevermind, figured it out
Old May 2, 2007 | 10:37 AM
StyleFront's Avatar
What did you figure out? I wouldn't think so unless you had a custom cam with some ridiculous lift.
Old May 2, 2007 | 10:39 AM
they dont need to be, but some do. stock springs have around 63 lbs of pressure whereas the supertech dual springs have about 93-95. I have a customer that was floating valves at 35 psi at 9000 rpm and once hs himmed them his problems went away
Old May 2, 2007 | 10:42 AM
Aby@MIL.SPEC's Avatar
on many engines that i have built for various manufacturer's that would run between 15 & 17k, we would set-up the springs ~0.020" -0.025" before coil bind.
this helps ensure / minimize the likely hood of of VTP contact during upshift/downshift over revs.
just be certain of the spring pressure when setting the springs up that way.
Old May 2, 2007 | 12:55 PM
trinydex's Avatar
that's some exceptional info right there!
Old May 2, 2007 | 06:43 PM
Liqquid's Avatar
What kind of engines?
Old May 2, 2007 | 07:26 PM
2.65L v8 engines that ran in the CART series
cosworth, toyota & honda
Old May 2, 2007 | 11:26 PM
SuPeRNeT's Avatar
How do you deal with the harmonics at that crazy rev?
Old May 3, 2007 | 03:58 AM
gt42r's Avatar
Don't forget to use the special thin valve stem seals with these springs cause you'll have a big problem if you use the stock seals.
Old May 3, 2007 | 05:06 PM
Noogles's Avatar
For a Beehive race spring, ti valves, lock and retainers thats all fine and dandy but thats crazy for a production spring anything closer than .070 to coil bind and you are asking to break them. I've pushed them close to .04-.05 but that was a triple spring with dual isolators. 600 seat 1300 open pressure, we had to run 5/8 pushrods. i've actually snapped the nose off of a jessel Fully optioned j2k rocker
Old May 3, 2007 | 05:08 PM
EvoDan2004's Avatar
i used what b/r sent me. i thought they was the stocker's. i have no problems
Old May 3, 2007 | 05:40 PM
Exciting News's Avatar
The stockers supposedly get chewed up by the inner spring and needless to say you're looking at a headache. I can't imagine Buschur sending you something that wouldn't work. You should be fine.
Sheasta
Oct 21, 2015 03:28 PM
Craig King
26
Oct 31, 2012 05:42 AM
strokedt67
10
Mar 29, 2008 11:42 PM
Steve@NoLimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
Jul 30, 2007 02:00 PM
althemean
Aug 22, 2006 11:26 AM
