Miss shift/Grind
Miss shift/Grind
Okay. I have a short shifter. I also have some Buschur underhood shifter bushings NOT YET installed. At the track, whenever i shifted... it would not go in (even if i left the clutch in until i was shifted) or it would go in and make a grind noise. Not a loud grind like when you miss shift usually. It goes into gear but still grinds. Will the busings solve this problem?
+1, for some reason a simple flush with this as a replacement fluid fixes things you never would expect it to. Before going through the hassle of replacing a t.o.b. or synchro..give this a shot!
Kreeker
Feb 5, 2016 01:52 PM
bluebyu34
15
Feb 28, 2013 03:01 PM
ArchieBabes
17
Feb 16, 2013 06:11 PM
therunningskier
12
Feb 27, 2009 10:02 PM
