Results of BG Synchroshift
Old Jul 22, 2004 | 04:30 PM
  #31
The Reject's Avatar
Did you add the friction modifier? You can order if from most mitsu dealerships. Its a very common thing in the dsm world. Makes a huge differance.
Old Jul 22, 2004 | 04:35 PM
  #32
GreedMOTO's Avatar
I too had the 1-2 grind, but when I changed to a B&M short throw shifter, I also changed the crappy rubber bushings to the brass ones from LancerShop. I have to admit, the tranny is a whole new animal. I beat the **** outta my tranny and have NEVER had a grind or miss.
I still need to put my BG fluid in, but so far...no complaints here.
Old Jul 22, 2004 | 04:45 PM
  #33
Buckkaaaa!!'s Avatar
you can always shift into 1st provided that you rev match correctly.... the only thing is 1st is VERY hard because if you don't slide it in right at the right rpm.... it'll be harsh.... personally i just NEVER do this now... i did a few times in my old car during autocrosses but it never feld "good" (at least not as good as a perfect rev match into 2nd). Keep in mind that i only did it before because the powerband in that car wasn't as wide as the evo's (vtec car)!
Yeah I changed to pennzoil synchromesh at 3000 miles... only been a few hundred since, but its definitely smoother!
use2vtec
20
Feb 10, 2009 02:26 PM
aboh6leenz
Sep 27, 2007 06:37 PM
Johnny Boy
Aug 24, 2006 07:30 AM
Mooshu1221
Aug 1, 2005 07:39 AM
DizeLLx
Mar 8, 2005 09:43 PM
