Denso Iridium Spark Plugs...help?
Old May 11, 2007 | 01:40 PM
Alphex's Avatar
I went to autozone and got a set of Denso Iridium plugs for my 06 IX SE. My baby has just 10k miles on her, and when I pulled the factory plugs (NGK Iridiums), they were dark brown and looked really corroded which that alone scared me a little bit. :< Anyway, I pull the plugs out and compare to the new Denso's and the NGK plugs threaded area was about 1/2" longer than the Denso's, so they stock ones were actually larger plugs. I did the swap and haven't had any trouble, but I'm hoping for someone to know if I did the right thing or not?
I checked Denso's website and they dont' list any plugs for my car. I checked Autozone's website and they don't list any denso plugs for it either... Of course, I do this all after I bought the plugs from my local Autozone... ugh.
Also, they told me these plugs came pregapped, which I believed, but is this correct? If not, does anyone know the exact gap they should have?
Old May 11, 2007 | 02:35 PM
Speed Element's Avatar
For stock EVO 9, the DENSO part number is IKH22. Most of the Denso ones are pregapped.
1 step colder is IKH24
Old May 11, 2007 | 08:59 PM
wrcwannabe's Avatar
Hmm 1/2inch shorter on threads? You got the wrong plugs or are describing the difference incorrectly. Are you sure the actual threads are 1/2 inch shorter? Maybe you meant that the metal body is shorter but the threaded portion is the same length ? I find it hard to believe the car runs if the electrodes do not even get down to the combustion chamber
Check the p/n that Speed Element posted.
Milburn
Old May 14, 2007 | 11:01 AM
Alphex's Avatar
Yes - checking the part numbers posted later today, but I am describing it correctly, the actual threaded portion is approximately 1/2" shorter than the stock NGK plugs, I thought the exact thing as I looked at them... thinking "it's so much shorter, how is it even going to fire?" But it is...
Anyway, I'll repost once I've checked that part number.
Old May 14, 2007 | 04:45 PM
greentrbo95gst's Avatar
Dark brown is a good color. You don't really have any mods yet so the car is running with the factory ecu settings. AFR should be perfect. I would be getting scared if the plugs were white or the tips were melted.
Old Aug 5, 2007 | 08:07 PM
Alphex's Avatar
Sorry to revive an old post, but I finally found the spark plug packaging, and the part number is IK16#4/5303#4. Sooo, any ideas on what happens if you use a spark plug that's not the right part number? It's not longer than the stock plugs, so there's no worries about it striking the pistons or anything... but still... I'm a little concerned. Any thoughts?
Old Aug 6, 2007 | 01:38 AM
red evo8's Avatar
ikh24 optionsauto sells them for the beest price ive found same length as stockers just a step colder
Old Aug 6, 2007 | 02:00 AM
moreryce's Avatar
DUDE... dont use those plugs man.. and dont ever go to autozone.. i run an autoparts store... PM me.. you are running a really hot plug...
Old Aug 6, 2007 | 10:58 AM
Alphex's Avatar
oh crap
Ok, now I'm worried. I've been running those plugs for about a month now, not very many miles though... I feel like an idiot, I should've gone back to the store as soon as I noticed a difference in the plugs, but I was switching from the stock NGK's, so I assumed that was why they looked different. bleargh
Old Aug 6, 2007 | 12:30 PM
red evo8's Avatar
lol wow i hope you havent been getting on it around ever corner
Old Aug 6, 2007 | 12:38 PM
Alphex's Avatar
No, I don't race it or anything, it's my DD, and my commute is maybe 15 minutes one way, so I haven't put a lot of miles on it since the plug swap, needless to say, I'm on my way to the auto parts store for the correct plugs and the evo is sitting in the garage waiting...
Old Sep 26, 2007 | 12:45 AM
ttbestas's Avatar
denso iridiums worked perfect for me i run ik24 they even change to colder ik27 one minus expensive!
Emperor 4g63
16
Jun 8, 2017 12:50 PM
brakeboost980
26
Apr 3, 2015 02:17 AM
Blacksheepdj
Oct 19, 2007 12:05 PM
Cesarjr23
108
Sep 27, 2007 11:52 AM
EvilBlueEvo8
49
Mar 11, 2005 02:51 PM
