reving to 8k safely
Old May 17, 2007 | 03:25 PM
  #31
scorke's Avatar
Originally Posted by evo8604
7800 is the recommended rev-limit for a stock 4g63's valvetrain. surely people rev higher and lower, time is the only thing keeping the engine alive depending on the tune and or who tuned the car.
cams+springs+retainers will allow you to rev higher. for instance fully built 2.0 race engines are usually around 9000-9500 rpm rev limit.
fully built 2.3's usually do not exceed 8200 rpm.
7800 is the stock recommendation, however they also reccomend a lot of other things that most owner's ignore
How do cams allow an engine to rev higher?
Scorke
Old May 17, 2007 | 03:31 PM
  #32
iTune's Avatar
You must understand....again. The stock valvetrain is not the only thing limiting high revs. The stock rod ratio and stock rods are also a very limiting factor in high revs(due to the very high g forces involved with piston acceleration at revs over 8K). Once built properly, the bottom end can handle more revs(when built with the proper rod ratio for high revs, along with good billit rods, ARP rod bolts...ect) and the valvetrain must be built as well to keep valve float in check at these revs.
We choose to stay with a 2.0l, built with the proper rod ratio to facilitate high revs. A stroker will not have the correct rod ratio to promote high revs.
CJ
Old May 17, 2007 | 03:37 PM
  #33
Ludikraut's Avatar
Originally Posted by scorke
7800 is the stock recommendation, however they also reccomend a lot of other things that _most_ owner's ignore
correction: _some_owners_
l8r)
Old May 17, 2007 | 03:40 PM
  #34
evilevo2006's Avatar
Well what can a 2.3 rev to safly???? 8k?? No more then that??
Old May 17, 2007 | 03:44 PM
  #35
scorke's Avatar
^ depends on who you speak to, what you consider safe, and what you want out of your motor.
The whole idea of a 2.3 is to increase tq, tq drops with RPMs so most 2.3 guys aren't too concerned with screaming there motors and the ones that are concerned with revving to the moon run 2.1s.
Doug from TopSpeed said I was safe to run up to 8300 rpms with stock valve springs on my built 2.3.
Scorke
Old May 17, 2007 | 04:13 PM
  #36
Well I would like a 8krpm capable daily driven safe setup. If a 2.3 can do that then that's what I want. Reason for picking a 2.3 is
A. The extra trq
B. Able to rev too 8k
C. Faster spool up on biger turbo's
There my main reason.
Old May 17, 2007 | 04:16 PM
  #37
Ludikraut's Avatar
It will depend on which kit you go with. In other words, it will depend on which valvetrain you're running, which pistons, which rods, and which crank. For example, AMS sells different 2.3l kits. Between them, their 2.3RR can be revved higher, since it uses different internals than their "standard" 2.3 stroker.
Furthermore, if you put together a balanced setup, then there may not be a need at all to rev out to 8K. 7500 RPM on a 2.3L GT35R setup seems to work fairly well with the stock gearing, judging from the few dyno charts I've seen of that type of setup here on the forums. If you're going with a smaller turbo (i.e. GT30, 50 trim, or FP Green), then it would definitely be pointless to rev beyond 7500 RPM other than trying to avoid shifting into 5th on a 1/4 mile run.
l8r)
Old May 17, 2007 | 05:52 PM
  #38
EvoRecordSetter's Avatar
A. The extra trq
2.3 Bottom end has nothing to do with B.
Old May 17, 2007 | 06:06 PM
  #39
scorke's Avatar
Yes and no..... the 2.3 CAN do that, but so can a stock build.
Scorke
Jhaze71
Aug 13, 2017 07:31 PM
beetle_orange
Jun 25, 2016 07:55 PM
Xene
For Sale - Cars For Sale
13
Jun 17, 2016 07:42 PM
mr2lover55
Jan 22, 2016 07:48 PM
SSMCL9
Nov 5, 2015 08:26 AM
