synchros $$$$$
Old May 20, 2007 | 08:12 AM
DESERTEAGLE50's Avatar
synchros $$$$$
how much should it cost for synchros to be installed
Old May 20, 2007 | 08:46 AM
Warrtalon's Avatar
Doing the synchros themselves is not a big job, but unfortunately, to get to them, you have to drop the trans. It's basically a full clutch job plus opening the trans and replacing the synchros, so that could be anywhere from $600-800.
I'd make absolutely sure it's your synchros before replacing them. Often times, it's just a clutch going bad or the clutch needs adjustment. Also, Mitsu has replaced a lot of synchros under warranty in the past, because it was a known problem. Your car is new, so they should fix anything like that under warranty anyway.
Old May 20, 2007 | 03:43 PM
No My Car Is Black Listed Way To Many Mods .so I Wonder If I Should Just Buy A Trans Already Built .the Clutch Is Good Just Picked My Car Up Today With New Act And Street Lite.we Tried Adjusting Pedal With No Luck.i Worry About Fixing This One And The Same Thing Happens
Old May 20, 2007 | 03:49 PM
vwjeff's Avatar
Send the trans to Buschurs... Bottom line
Old May 20, 2007 | 04:51 PM
Warrtalon's Avatar
Turn off CAPS LOCK dude...
powerdriver
Dec 13, 2016 04:06 AM
amsevokid
Apr 17, 2011 11:19 AM
omgivec
Jan 30, 2009 01:25 PM
JSYEVO
May 23, 2005 03:08 PM
Eric Lyublinsky
13
Apr 16, 2003 10:09 AM
