synchro for RA
Old Jan 28, 2009 | 04:16 PM
omgivec's Avatar
synchro for RA
hey guys how much are the synchro's for the RA, since my third gear one its dead. thanks
Old Jan 28, 2009 | 04:35 PM
snakoil's Avatar
maybe it is not your third gear but the shifter cable bushings or shifter cable themselves
For my part I changed bushings twice in 3 yearrs and changed the cables few weeks ago
The bushing tend to seize and if you don't take care of it the cables will bent
starts with the 3td, then 1st and at the end complete higher section is out
Old Jan 28, 2009 | 05:07 PM
Christoforo's Avatar
Could someone post pictures/a how to on how to replace these things? I have a feeling mines going too, not now but sometime this year probably.
Old Jan 28, 2009 | 08:43 PM
bruce988jl's Avatar
ahahhahaha
If you don't know whether or not its going then you shouldn't be thinking of replacing it. The synchros are mid-gears in your transmissions, they essentially guide your shifts into gear. Replacing synchros is basically rebuilding the transmission. Something you shouldn't give a shot unless you have someone there to help, a lot of free time to mess around and a ton of patience. Here are some photo's of my chewed up synchro's.
Note the brass piece is the synchro:
More photos of the internals of our tranny here:
http://bruce988jl.smugmug.com/galler...25329939_9a8dn
I forget how much each synchro cost I'll get back to you on that.
Old Jan 28, 2009 | 11:35 PM
Thomar's Avatar
interesting.. the wear on those synchros doesnt look that bad. unless i'm not gettin it. lol
Old Jan 29, 2009 | 04:40 AM
bruce988jl's Avatar
Eh, actually I think that's the wrong picture, there's a picture of a synchro with a chunk missing out of the alignment portion of it. Also all the synchro's I removed had a little metal lip on the edge of it from a combo of my harsh driving and a bad clutch hydraulic setup that comes in the RA. Did I mention that I went through 3, yes 3 master brake cylinders and 2 slave cylinders. I had the lower stock clutchline start leaking on me after fixing the slave and master so I replaced the entire line system with braided lines. Following that my tranny went, had it rebuilt replacing 1-2-rev synchros, 2nd and rev gear, and a ton of other misc parts. 3 weeks after the rebuild it went again, brought it back to the guy *****ed him out. And to this day its "being looked at" (week from when we dropped it off).
/end rant
(ever wonder why I hate my car its because of that... and because I've replaced the fan controller 5 times! yay!)
Old Jan 29, 2009 | 08:58 AM
Thomar's Avatar
wow. other then the struts that are being replaced under warranty, i've had no problems. you're car's a lemon. lemon law?
Old Jan 29, 2009 | 10:34 AM
omgivec's Avatar
well think its a sychro it only grinds when i pass 5000 rpm, if i drive slow it doesnt make any noise and it frinds in third and fourth gear. could be anything else, i dont know anything about trannys
Old Jan 30, 2009 | 01:25 PM
Canada_Comp's Avatar
check my thread https://www.evolutionm.net/forums/la...questions.html. I also have 3rd gear problems with grinding. It's not the bushing since I clean and lubricate them yearly. there's also videos of mine grinding. prices would be awesome
boost556
15
Dec 29, 2018 03:01 AM
powerdriver
Dec 13, 2016 04:06 AM
tsidrift1
Jan 1, 2016 08:20 AM
Matt_Jagg7
Jul 21, 2009 11:45 AM
JSYEVO
May 23, 2005 03:08 PM
