Alky horror stories???
Old May 22, 2007 | 06:29 AM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
After having a few years out there, I'm lookin to see if generally alcohol injection systems have been good or bad for engines. I've heard that running alcohol has many pros even outside being able to run high boost. I'm wondering mainly, how many people have had catastrophic failures due to malfunctioning(for whatever reason) alky systems?
Old May 22, 2007 | 06:43 AM
TeStUdO's Avatar
Almost all failures are due to lack of monitoring of the system or lack of a good failsafe. If you dont run a good failsafe or monitor air/fuel constantly with a wideband you are setting yourself up for failure.
Old May 22, 2007 | 06:51 AM
So I've heard. This is what I'm looking for. What's been the cause of peoples failures? Or, has anyone had a reliable failsafe system save their motor?
Old May 22, 2007 | 07:04 AM
scheides's Avatar
EvoM Moderator
Been running SMC kit for about 6 months now with zero issues. It tells me when it's low on alky and I go easy until I top off the tank. Ran through about 15-20 gallons of denatured alcohol so far
Old May 22, 2007 | 07:09 AM
4G63 T's Avatar
2 yrs now witkh smc...pump was replaced under warranty due to leak. love it.
Old May 22, 2007 | 07:10 AM
lexat20's Avatar
I watch my gauges like I watch my rear view mirror. If you monitor everything, chances are you will not have a problem. I have yet to hear a pump failing unless there was some faulty wiring. Been running 100% meth for over a year.
Old May 22, 2007 | 07:14 AM
SlowCar's Avatar
monitor your flow, fluid level, afr, egt - any of these parameter outside the preset limits, send all boost to the wastegate with a failsafe.
not fun racing and having to watching gauges
Old May 22, 2007 | 07:33 AM
HmanEVO's Avatar
I've been running a SMC kit with 100% meth for over a year now. No complaints or failures to speak of. I check the pressure on mine every so often and always hit the test button for a sec before I go out on a spirited drive. Like others have said, get a nice failsafe and you've got nothing to worry about.
Old May 22, 2007 | 07:42 AM
tweakdsm's Avatar
SMC kit here with safety injection, at 28psi on 20g, 5k on the car so far, no problem, IF you take care of the kit, make sure nothing leaks and never run out of meth - you will be safe! I love it. btw I run Evoscan from time to time just to check on everything.
GM People with grand national's run meth, all their life.
Old May 22, 2007 | 07:44 AM
Viciouslord's Avatar
heres an old video but you get the idea.... i have the same failsafe setup and it works great.... TTP
Old May 22, 2007 | 08:29 AM
TeStUdO's Avatar
Really? I thought it was just common knowledge that shur-flo pumps failed after a while.
Old May 22, 2007 | 08:37 AM
lexat20's Avatar
You could be right. Mine has had zero issue so far though. I bought my kit used from Jrod@buschur, not sure how much use it had before me but I've got about
15k out of it so far.
Old May 22, 2007 | 08:43 AM
idriveanevo's Avatar
what is the most reliable system?
Old May 22, 2007 | 09:28 AM
big_huff's Avatar
In that video what device is that telling you your boost and your egt?
Old May 22, 2007 | 10:00 AM
Noogles's Avatar
I'm pretty sure i'm the one who runs the most amount of methanol on this forum.
I've never had any problems. even thought my kit is a bit custom i run 4 m15 nozzles at 120psi (can do 150 if wanted) being fed by twin Weldon 2032-A pumps.
Never had any sort of problem.... other than running out of methanol, lol
