CBRD and AMS Step 1: it arrives
Old May 24, 2007 | 11:37 AM
  #46
Altr_Evo's Avatar
i wish the evo wasnt such a money pit
Old May 24, 2007 | 11:43 AM
  #47
BlackIX's Avatar
Did you have to trim the rear diffuser at all when switching to the AMS exhaust?
Old May 24, 2007 | 11:51 AM
  #48
CBRD's Avatar
no it fit perfect....
cb
Old May 24, 2007 | 06:21 PM
  #49
hondafan's Avatar
is that LICP the same as the one AMS sells for the stock turbo? i remember their old one used to taper, maybe it's special for the kits though.
Old May 24, 2007 | 07:02 PM
  #50
Blue Evo 8's Avatar
the car is lookin great
Old May 24, 2007 | 10:50 PM
  #51
Whoop_ass's Avatar
naaa!! the LICP that comes with the AMS kit is different to the stock LICP!
i have the same kit and it should be going on in about a month or 2.
Chad you workshop is so supper CLEAN man
truly awesome dude!
keep up the good work
Old May 25, 2007 | 07:41 AM
  #52
CBRD's Avatar
thanks guys...
drove the car home last night, unfortunately i haven't been able to put it on the dyno, im home ill with a stomach virus ahhhhhhh! first impressions... nothing leaked... at all.....
and the anti-surge compressor cover sounds significantly different than the standard 35r inlet we were running before... it sounds like a smaller turbo when it spools...
ill try to dyno it tomorrow, or later tonight if i make it in to work today!!
more to come guys!
cb
Old May 25, 2007 | 09:20 AM
  #53
AutoMotoSports's Avatar
Everything looks GREAT Chad. We have never used those studs but the kit fits like a glove with the standard harware. Thank you for the tip.
Sorry I was not able to get in here earlier but from the second we saw CBRD's setup and track record we knew they would embody everything we do here at AMS. This is a partnership that was set in motion long before we even knew each other.
Keep up the great works guys and we all look forward to the findings.
Eric
Old May 25, 2007 | 10:07 AM
  #54
CBRD's Avatar
Eric,
thank you. We spoke to many different companies, but AMS gave us a comfort level that is hard to find. This industry is full of empty promises, and AMS has fulfilled on all of theirs.
The car will be on the dyno and in action very shortly... back to back comparisons will be interesting...
cb
Old May 25, 2007 | 04:44 PM
  #55
I think you will be pleasantly surprised on the increase in power, spool and torque
Eric
Old May 26, 2007 | 04:55 AM
  #56
blackblaze427's Avatar
why did you buy one then? thats what being an enthusiest is all about
Old May 26, 2007 | 09:09 AM
  #57
CBRD's Avatar
well,
did some initial pulls
14.5-15.2 psi (on WG spring pressure) same map as before, we saw 320whp/286wtq
20psi (aem trueboost) 396whp/319wtq same map
more to come, i expect an easy 450whp on pump at 24.5 psi with some tuning, and higher torque.
cb
Old May 26, 2007 | 09:59 AM
  #58
CBRD's Avatar
ok, a little more, same map, we were running before, richened it up a little, up top..
23psi = 420whp/346wtq
I am having some issues with the knock sensor (fault code, so i think it may be going south) im going to replace it on tuesday... and do some more dyno-ing...
note, this is on the stock ecu.... AEM will go on late this week..
So far I am very impressed, since the wastegate is dumped back in, and we are running the resonated test pipe!
again, more to come!
cb
Old May 26, 2007 | 04:10 PM
  #59
hondafan's Avatar
what made you decide to go stand-alone, chad?
Old May 26, 2007 | 05:43 PM
  #60
phenem's Avatar
I bet he got it free or really cheap.....
~Zach
