Found out what the sound coming from my tranny...
Old May 25, 2007 | 12:36 PM
RSGuy's Avatar
Found out what the sound coming from my tranny was...
Hey guys,
A week or so back an awful loud sound was coming from my tranny. Also, the car would not go into gear easily and had NO power whatsover. Keep in mind I just had a new clutch and flywheel installed a month or so ago. The shop I took it to pulled the tranny and found that all but one of the flywheel bolts had backed out and basically the clutch and flywheel couldnt work properly. This also caused my crankshaft to get marred up from all of that heat. My question for you guys is whether you think this was caused by improper clutch install (the mechanic at the shop said he didnt see any lock-tight on the FW bolts) or if it was just bad luck? Not only did this cause my brand new $350 flywheel to be destroyed, I had to pay another $1,000 in labor costs. What do you guys think?
Old May 25, 2007 | 12:40 PM
nObject's Avatar
Sounds like installation error..
Old May 25, 2007 | 12:46 PM
Chris@nolimitmotors's Avatar
Sounds like the flywheel bolts wernt torqued correctly.
Old May 25, 2007 | 03:02 PM
amnbrueckner's Avatar
Id complain to the shop that installed it. Its obvious that it was an error on their part.
Old May 25, 2007 | 03:06 PM
2theMAX's Avatar
I'd fight for reimbursement for a new crankshaft also. Take the money and build the motor.
Old May 25, 2007 | 03:08 PM
matyb's Avatar
totally sounds like an error on there part. cars are cars and they all do crazy things. but in all of my years i have never seen one take its self apart without some kind of user error
Old May 25, 2007 | 03:12 PM
Curt@MrLed's Avatar
Former Vendor
sue them, its there fault.. hell even said there was no loctite on there..
Old May 25, 2007 | 03:49 PM
Aby@MIL.SPEC's Avatar
1 of 2 things:
1. the flywheel wasnt torqued @ all
or
2. the flywheel didnt seat fully onto the crankshaft even though the bolts were torqued.
this could have happened due to debris between the flywheel & crankshaft, out of tolerance flywheel machining, etc. so after very little use, the flywheel seated = making the bolts loose, as there was no clamping force being applied since the flywheel wasnt fully seated onto the crank.
it sucks either way.
they should pay for it, as it was comlete assembly error. even if the flywheel was defective, they installed a defective flywheel.
did you buy the parts from the installer?
Old May 25, 2007 | 03:53 PM
MONSTARR's Avatar
Get a lawyer....a good one....you can borrow mine if you want, but she's not cheap.
Old May 25, 2007 | 03:59 PM
tripperfx3's Avatar
Yea... Defiently sue em and make them pay for your lawyer fees too!
Old May 26, 2007 | 06:06 PM
frost318's Avatar
Get MONSTARR's lawyer.........There at fault
Old May 26, 2007 | 06:21 PM
cssaddictm4's Avatar
1000$ for labor is outrageous....
Old May 26, 2007 | 08:10 PM
riceball777's Avatar
installation error
the only way bolts can back out is if they were not tighten to the correct torque
Old May 26, 2007 | 08:56 PM
ImJoey's Avatar
scary situation
Old May 27, 2007 | 12:43 PM
matt55's Avatar
Originally Posted by RSGuy
Hey guys,
Wow sorry to hear Fred
What shop ? and it def sound like that shop dropped the ball !
MitsuJoe
468
Feb 20, 2016 11:17 AM
Mr. Evo IX
12
Jun 26, 2008 09:21 PM
Cow town racer
Jan 5, 2008 12:38 AM
Andrew LB
34
May 1, 2006 12:16 PM
MitsuJoe
Aug 1, 2004 01:59 PM
