how to remove starter
Old May 25, 2007 | 05:16 PM
masterbetter's Avatar
what is the best way to get the starter off? the bolts were no problem but i cant seem to wiggle it out. please advise
Old May 25, 2007 | 05:23 PM
ak47po's Avatar
capture1-1.jpg?t=1180139317
Old May 25, 2007 | 06:59 PM
the starter seems to be real tight against the flywheel its hard to pull it off, any tips?
Old May 25, 2007 | 07:05 PM
smokedmustang's Avatar
Got to take out the half-shaft,and lower motor mount/brace. At least my guy had to do all that stuff to get it out.
Old May 25, 2007 | 07:23 PM
ny-quiL's Avatar
For a starter?!
All the times I have dropped mine off it comes right off/out (3-4 times removed) - are you sure that you have removed all the bolts, there is a real long one that is on the transmission side of the car.
Old May 25, 2007 | 07:26 PM
scubaEVO's Avatar
All you need to do is take out the two bolts that bolt the starter to the tranny, unclip the black plug, and take the nut off the power wire. Then pull it out by rocking it back and forth. You do not need to remove anything else.
Old May 25, 2007 | 07:28 PM
scubaEVO's Avatar
One bolt head faces the driver side and the other faces the passenger side. The driver side bolt is the long one.
Old May 25, 2007 | 07:32 PM
yea i undid both bolts, unhooked ground clip, removed bolt to power. i pushed pulled rocked until i was exhausted. it wont move at all
since im going to replace the starter, should i just take a hammer and beat the crap out of it
Old May 25, 2007 | 07:38 PM
Silver05Bullet's Avatar
hell yeah
Old May 25, 2007 | 10:12 PM
Luis@TTP's Avatar
no a slight love tap with a rubber malet wont hurt but if your havin trouble getting it out the deffinetly try to rock it from side to side it is possible that the dust shield between the engine and transmission could be bent or possibly jammed on to it if that doesnt work put the long 14 mm bolt in back in thread it in like 6 turns and use a hammer and socket to nock it loose but make sure it has space to come out and not damage anything.
Old May 26, 2007 | 09:51 AM
evobob8's Avatar
dude theres 3 bolts, i took mine out today. u have 2 on the passanger side (smaller bolts) and one longer one 3 maybe 4in facing the other direction on the other side of the starter. get them all off itll fall down when u get the long bolt off. good luck. Just dont start swingin a hammer at it.
Old May 26, 2007 | 11:15 AM
DANRR05's Avatar
Strange, took mine off the other day, 2 bolts and it fell off.
Old May 26, 2007 | 11:23 AM
Luis@TTP's Avatar
to be honest there is onlt 2 bolts and one nut and a plug that you should have to pull. i remove them very often as a matter a fact all the time has on long bolt that you can remove from the driver side and one from the passanger side. in this guys case he is saying he removed them and the started is stuck in place we are trying to help him remove it by putting a 14 mm socket on the driver side bolt (the long bolt) and tapping it with a hammer it should be able to come free (yes you have to thread the bolt in a few turns)
Old May 26, 2007 | 11:59 AM
ill try hammering a socket>14mm bolt today, thanks for the tip
ZeRoMaX
Jan 26, 2017 08:42 PM
bkk_evo_guy
Sep 5, 2016 09:13 AM
nor11384
Feb 20, 2016 05:06 PM
BlackRalliart#1
Aug 30, 2010 02:29 PM
mojoe
Feb 20, 2006 06:01 PM
