how to adjust clutch
Old May 29, 2007 | 06:17 PM
WILLS EVO's Avatar
i was wondering how to adjust on how low the clutch can ingage my clutch is way to high
Old May 29, 2007 | 06:21 PM
Ralph's Avatar
http://evomoto.com/tech_info.php?tec...dd902dc99db29d
Old May 29, 2007 | 06:29 PM
WILLS EVO's Avatar
thanks!!
Old May 29, 2007 | 06:31 PM
Kdash106's Avatar
stock is suppose to engage at high point, but if u must, i think there is a nut right behind the clutch paddle, loosen that nut and adjust the rod that is connected to it. i don't know which way to turn is to set high and low, you have to try it out.
Old May 29, 2007 | 06:34 PM
Kdash106's Avatar
ooops. didn't know someone posted be4 me.
Old Jun 17, 2007 | 07:46 PM
Nitrotiger's Avatar
so do you think grinding at high rpm in 5th only could be a warn clutch so it needs to be adjusted?. Maybe the pressure plate is not release all the way do to wear.
Old Jun 17, 2007 | 07:51 PM
hondafan's Avatar
here ya go. do it this way as it's the proper way to check to not cause damage to synchros or other components. you really shouldn't adjust the pedal to where you want it to be, there is a certain spec it's supposed to be within for everything to work properly.
http://www.teamrip.com/clutch%20adjustment.html
Old Jun 18, 2007 | 11:28 AM
sonicnofadz's Avatar
A clutch that engages too high runs the risk of having too much preload on the pressure plate (the throw bearing is riding on the fingers). Too much preload will cause slippage under power.
Old Jun 21, 2007 | 05:57 PM
john blaze's Avatar
thanks i was looking for this everywhere
Old Jun 21, 2007 | 07:13 PM
evil4g63's Avatar
my clutch engages almost all the way out and its an aftermarket act. it was in the car when i bought it but it feels fine under driving conditions but when i try to launch it (only 2 times) it slips all the way out. i think sonicnofadz just answered my questions. thanks
DJErickG
Sep 26, 2017 06:26 PM
evo1008
Nov 5, 2014 05:29 AM
silentkiller
Sep 28, 2014 10:03 PM
Dragking2189
Aug 20, 2013 09:23 AM
URNVS
May 30, 2013 02:59 PM
