Ultimate Racing - 12.1 @ 110mph
Old Jun 23, 2003 | 01:29 PM
Ultimate Racing's Avatar
VIDEOS
As I promised...the videos...
As you can see from the first run...our problem is running out of 4th gear and hitting 5th.
12.172@110.23 mph
12.205@112.79 mph
Thanks
Darryl
Old Jun 23, 2003 | 02:51 PM
Alfriedesq's Avatar
Interesting - - I was able to go 113.94 still in 4th gear - I wonder if your gears may be different???
I need to take a risk with the local PD and conduct a test to see exactly at what speed it hits the fuel cut in 4th gear
The gearing is going to be a limiting factor to reach mid 11's - we may need a different 4th gear - OR a change of the final drive ratio - both of which I have NO idea if they are available
Old Jun 23, 2003 | 04:27 PM
Shahul X's Avatar
great videos! thanks for the clips !
-Shahul
Old Jun 24, 2003 | 05:21 AM
jotan82's Avatar
congrats! awesome times!!! 11's are soo close!
Old Jun 24, 2003 | 05:29 AM
Red EVO TME's Avatar
thanks for great videos. amazing times. congrats !
Old Jun 24, 2003 | 06:25 AM
Incognito's Avatar
Al, since no different gearing or FD is available at this time, you are left with 2 choices. You can try to tach your car out higher, or you may want to try switching wheel/tire size. Run a taller tire and you'll be OK without shifting 5th.
Old Jun 24, 2003 | 06:30 AM
DB8GSR's Avatar
Darryl... congrats on the new times. 11's is just a hair away.
Old Jun 24, 2003 | 12:24 PM
AustinEvo8's Avatar
Check with Norris Designs...They have a 4.11 gearing to change the shift points.
Old Jun 25, 2003 | 07:27 AM
Saposat's Avatar
Congratulations!!!! Guys. I see 11`s very soon.
good Job.
