ARP Rod Studs
Old Jun 7, 2007 | 03:57 PM
Olynth's Avatar
ARP Rod Studs
hi all.
i am running 25 psi on my evo. do i need to change my rod studs?
what are the advantages and disadvantages of using arp rod studs?
Thanks.
Old Jun 8, 2007 | 08:04 AM
phillytec's Avatar
Smile
better strength of ourse less chance of seperation. Many shops recommend replacing them when installing cams.
Are you doing 25 on stock turbo?
Old Jun 8, 2007 | 10:18 AM
Olynth's Avatar
thanks. I am doing 21 cont and 25 peak on stock turbo.
Old Jun 8, 2007 | 10:24 AM
turboDan's Avatar
I believe the question was about "rod studs" and I think that you^^ are refering to "head studs" as I do not know of anyone who pulls the oil pan to do cams
Old Jun 8, 2007 | 01:11 PM
dudical26's Avatar
I dont think this is really an advanced topic. you would get more replies if you just posted in Evo General or Drivetrain section. Although if you are just asking if you need head studs then do some seaching, it has been covered many many times.
Old Jun 8, 2007 | 01:16 PM
UpstateEVOVIII's Avatar
If you do cams, you may as well do the head studs while you're in there. As a general rule of thumb, if you aren't doing cams...stock studs=fine for stock turbo. bigger turbo=upgraded studs.
Old Jun 8, 2007 | 04:49 PM
Olynth's Avatar
we will put cossy 272 cams tomorrow but we don't remove the head. so we don't need to change the Head studs I think. somebody said to me to change my rod studs. I dont know if its necessary. i need some help
thanks
Old Jun 11, 2007 | 07:26 AM
belizelittle39439's Avatar
It's not necessary unless you're running higher boost. However, if you've got them and you're putting some cams in you might as well use em.
Old Jun 11, 2007 | 09:01 AM
erioshi's Avatar
Now an opinion on upgrading rod bolds & main bearing studs!
I had the #1 rod bearing spin on a 40k engine. It looks like what caused the problem was a combination of hundreds of hours of track time, lots & lots of dyno time and the stretching of the stock rod bolts.
The stock bottom end hardware is probably fine for most people, but for high stress, high RPM use I would definitely upgrade.
Old Jun 11, 2007 | 04:09 PM
Olynth's Avatar
thanks for the comments.
we changed some parts and we will change rod studs as soon as possible.
Old Jun 16, 2007 | 11:36 AM
cushumpeng's Avatar
Never heard of a rod stud,it's head studs,or rod bolt.
Not trying to put you down,but some may not take it lghtly,so giving you the correct term to help you out.
Old Jun 16, 2007 | 04:10 PM
Olynth's Avatar
You're right.
http://www.arp-bolts.com/Catalog/Cat...atalog029.html
there are 3 rod bolts. which i should buy ?
