recommend me some cams
Old Jun 11, 2007 | 11:19 PM
  #31
SilverShadow03's Avatar
Originally Posted by idriveanevo
how much power did you gain? stock turbo?
I gained 28 HP from my previous tune on Shiv's Dyno Dynamics after cam install. I'm currently at 280HP with my current setup. Stock Turbo on 91 octane crap gas.
Old Jun 11, 2007 | 11:32 PM
  #32
Evo8yurAMG's Avatar
Originally Posted by TTP Engineering
They are backordered because they are whored out, ebay style.
On top of that, they are made overseas and it takes a long time to get them back into the USA.
what....im pretty sure they are made at the crower cam shop in east lake area in SD... i have talked with him several times... if not then that is a huge suprise to me... he told me he uses his dads shop. and honestly...why wouldnt he
Old Jun 12, 2007 | 02:36 AM
  #33
Evo_7's Avatar
I am running HKS 280`s and have to say high end power is there....
Also you should look in to JUN 264`s or BR Cams....
Old Jun 12, 2007 | 02:52 AM
  #34
EvoDan2004's Avatar
I have revolver cams. I'm so glad I did not go with any other cam. O and if you love the loppy idle lol these cams deffenently deliver. Plus I made sick power... I hope there still a good cam for my 50trim kit...
Old Jun 12, 2007 | 05:59 AM
  #35
Paul Nelson's Avatar
He sold out of the cams he has and the new order is coming from over seas...
Old Jun 12, 2007 | 03:00 PM
  #36
idriveanevo's Avatar
so something around a 272 will be good now and will work great with meth and a lil bigger turbo?
Old Jun 12, 2007 | 03:04 PM
  #37
Evo8yurAMG's Avatar
ahhh i c...thanks for the clarification
Old Jun 12, 2007 | 03:13 PM
  #38
TTP Engineering's Avatar
Yes, that is a fine plan.
Old Jun 12, 2007 | 03:23 PM
  #39
how does the helix v2 272s compare to others??
Old Jun 12, 2007 | 03:32 PM
  #40
All I can do is speak from installation experience, but we went to install shift_fast (evom member) cams of this make and duration and just like the compcams problems with the cam angle sensor bolt hole not being drilled and tapped correctly, these suffered from the same problem and would spin freely in the cam.
Needless to say I swapped in my OWN personal GSC 280 280's from my shopcar MR so he would have a nice set of performance cams. Otherwise he would have wasted a 2 hour trip for an install that could not have been completed.
Old Jun 12, 2007 | 03:35 PM
  #41
ok, thank you. ill just stick with names i know, like gsc and hks maybe a couple others
Old Jun 12, 2007 | 03:54 PM
  #42
rcheung's Avatar
I like my HKS 264/264. They were a big difference on the stock turbo. On my initial tune I made about 284hp/260trq with intake, turboback exhaust and boost controller. On my second tune I had an aftermarket exhaust manifold, O2 outlet and 264/264 cams and made 320hp/300 trq.
Old Jun 12, 2007 | 03:58 PM
  #43
Apex Racer's Avatar
I have 272 xs engineering cams. I absolutely love them. I felt a day and night change throughout the rpm range and they do not require springs and retainers. I got them from the evostore.com site I paid like 500 for them
Old Jun 12, 2007 | 04:02 PM
  #44
how much did you gain from them?
Old Jun 12, 2007 | 04:04 PM
  #45
Evolving03's Avatar
I have HKS 272's and love them- there was definitely a very noticeable difference in power (especially 4th/5th gear) when they went on. If I had it to do over, I'd probably go with the 280s though. If you're going to do it, do it big!
