GSC S2s or 272s with 4G64 Strocker
Hi guys,
In the process of deciding the cams for my setup. I have a built 4G64 with a GT35R and plan to rev to 8000rpms. As the subject says I need advice on what cams to use. I mean are the S2s only for higher revving 2.0l blocks or will they be good for my setup too. Also any video clip of S2s idling? how would you compare the S2s Idle to the HKS 280s as the S1 review on the forums say that the S1s idle better than the HKS 272s...
Thanks
Thanks
Go with something that has some really big lift. We've seen good numbers out of Buschur's new BF272's or a set of Revolvers (if you can find them). If you go HKS go for the 280's, the idle is loppy but totally stable and they make kick *** power!
Standing Z
Oct 19, 2009 08:54 PM
Aby@MIL.SPEC
Feb 4, 2008 01:16 PM
