MBC, Check Engine Light
Old Jun 28, 2007 | 12:36 AM
Vlad54321's Avatar
When I cap off the wastegate actuator, my check engine comes on, why is that?
Anyone else have this problem, and if so how dose one get around it, alos when I uncap it, it runs just a bit shaiky
Intake Manifol --- T --- one to BOV the Other to MBC then to wastegate.
Old Jun 28, 2007 | 07:04 AM
Warrtalon's Avatar
Huh? Why would you ever cap off the wga nipple? That's a critical part of the boost sytsem. You have to connect to it, not cap it off...
Old Jun 28, 2007 | 07:14 AM
Ricekiller81's Avatar
Yes its Critical that u do it correctly or else KAAABBBOOOMM
Old Jun 28, 2007 | 07:21 AM
mdsevo06's Avatar
There a great "How To" thread, for installing MBC....search, this is a easy step by step instruction.
Old Jun 28, 2007 | 03:35 PM
Kdash106's Avatar
i LOL'ed
Old Jun 28, 2007 | 05:19 PM
Vlad54321's Avatar
ok, maybe I said something wrong, I am talking about the Sensor thing that gos to the waist gate and the other one to the intake, its right under the filter/intake.
I was using the insturctings from this site that show to cap off the trubo/intake/ and 2 on the Waste Gate Actuator. then T off from the BOV and go to the wastegate,
I do understand how it works, and I am not getting any Boooms, my boost is where I want it to be,
I am just not sure what the sensor is for, and why it shows to cap it.
Old Jun 28, 2007 | 06:16 PM
Warrtalon's Avatar
That's the boost control solenoid, not the wastegate actuator. The wastegate actuator is the thing you are calling the "wastegate." The wastegate is actually inside the turbo, and the wastegate actuator actuates it with a rod connected to the gold housing where the nipple is.
Capping off the BCS doesn't cause a CEL, but if you don't plug in the electrical connector, you will get a CEL.
You are not getting any Boooms??? What?
Old Jun 28, 2007 | 09:50 PM
Vlad54321's Avatar
ahh... then why on that picture it shows it as the WGA? anyways so your saying I should not get a Check Engine light, well I guess I will try again, thank you for your help,
and what I mean by the boom is, my motor is not going to do that, because of not connectiong the MBC incorectly....
Old Jun 28, 2007 | 09:53 PM
Vlad54321's Avatar
umm... looking at it one more time... it is saying where the pipes are coming from, not what that sensor is, oops.. I guess I was calling it te wrong name...
what is that sensor for and what dose it do?
Old Jun 28, 2007 | 10:10 PM
Warrtalon's Avatar
I mentioned earlier that it's the boost control solenoid (BCS). I don't know what you mean by "sensor." The boost control solenoid is the solenoid that controls boost for the stock boost system. Fancy, huh?
I don't think you were reading the diagram wrong. I consider the diagram itself to be wrong. It should not say "turbo wastegate actuator" on the BCS. That top nipple goes to the intake. The turbo and wga lines go to a tee, and one line comes from the tee to the BCS, so it's mis-labeled, imo.
Old Jun 28, 2007 | 10:36 PM
WickedWhtMR's Avatar
ok.... ill answer ur question.. i dont like this diagram... although if your running a boost controller that is adjustable from the cabin.. i do see the reasoning. Connect the pressure side of the MBC to the nipple on the turbo elbow... and then connect the the other vacuum line comming off the MBC to the nipple on the WGA. Now... cap off the 2 nipples on the solenoid under the air filter box. And cap off the nipple on the bottom of the intake. One on the vacuum lines comming of the solenoid was going to this nipple. And after you have done all this adjust your boost (start low and work your way up). And then all should be right with your world
good luck
Old Jun 28, 2007 | 10:37 PM
ohh.... and dont forget to pull the neg terminal on the batt. Reset the check engine light
Old Jun 28, 2007 | 10:38 PM
Vlad54321's Avatar
if you dont mined me asking how do you have it set up?
Old Jun 28, 2007 | 10:43 PM
Warrtalon's Avatar
I have mine setup the way WickedWhtMR mentioned. I prefer using that turbo nipple instead of hacking into my BOV line, but both methods work well.
Rawger
18
Jan 8, 2013 05:21 PM
gerard
Oct 25, 2008 06:39 AM
sabastian458
16
Jan 20, 2008 01:08 PM
subrwho
Jun 15, 2007 05:12 AM
TogueMonster
19
Oct 27, 2006 01:07 AM
