ebay 02 housing vs ported stock
DB logged with the stock, ported stock, and ebay... the ebay put down more HP, you will see about 5 HP gain to the wheels i think it was. The ported stock did not perform as well. It may have been more HP. Do a search for O2 comparison, or email DB or call buschur and ask them about the numbers. You could also search for all posts started by DB
There's a huge thread from David Buschur showing the exact results on the same car with back-to-back-to-back runs. This information is readily available and is also common knowledge now.
ebay o2
dude-It's not like there is a stickied dyno compare thread anywhere, besides, there are many huge threads that are created after daivid makes a post, hence there are many threads to read through, unless your locked up in jail, i doubt that you'll want to spend the time to read through them all, unless your sitting @ home due to in-house lock-up or your just masturbating to every post made on evom...........
get a megan o2 housnig for $100-, call it a day. you can port a stocker to the inside diameter the ebsay unit comes in, if you tried to, you'll spend some time, even if you had new carbide bits. when your mid-way through, you'll be asking yourself "what the f-k am i thinking & I why didnt i just buy a ebay unit"
the choice is yours, how much is your time worth?
