HKS Cams
Old Jun 25, 2003 | 11:08 AM
sneakychaos's Avatar
HKS Cams
Are the cams that HKS makes, like the 264's / 272's different for a 1G/2G DSM as opposed to our EVO's?
Old Jun 25, 2003 | 12:31 PM
stevEVO8's Avatar
I believe they are the same
Old Jun 25, 2003 | 12:43 PM
EVO8LH's Avatar
they are not the same.. put them in my car (264) works get even on stock turbo
Old Jun 25, 2003 | 01:43 PM
Not quite sure exactly what you are trying to say.
Old Jun 25, 2003 | 01:47 PM
ru4real's Avatar
I think his badly-contructed sentence meant to say that the HKS 264 cams are different between DSMs and the Evo, that they work, and you can get additional power even with the stock turbo. Can someone with experience confirm that the cams are different?
Old Jun 25, 2003 | 04:02 PM
Z1 Performance's Avatar
Yes they are different for the DSM's and evo's...how so? Not sure, but they do have different part #'s 9which HKS actually is not known to do for items that fit various models)
Adam
Old Jun 25, 2003 | 04:17 PM
AMS's Avatar
AMS
They are different. Locating pins for the cam gears are in different locations and the intake cam now sits where the exh. cam sits on the DSM 4G63.
Old Jun 26, 2003 | 01:58 PM
Martin - ah yeah, point out the obvious why don't you
How are things there?
Adam
Old Jun 26, 2003 | 02:15 PM
Shahul X's Avatar
how hard are the HKS to find? I hear impossible..and you need a in tank feul pump? and are the 272 THAT bad in idle? and how so...?
-shahul
Old Jun 26, 2003 | 02:16 PM
Shahul X's Avatar
and power differances on the 264/264 setup vs 272/272 set-up
-shahul
Old Jun 26, 2003 | 05:07 PM
AMS's Avatar
AMS
Adam
Between the racing season and running the shop, I can't wait to take a vacation (in 2010!) You keeping busy?
I was thinking about the valvetrain geometry and if the take-up/let-down ramps would be affected by trying to use DSM cams (provided you could correctly relocate the cam gear pin, but I'll have to put some more thought into it.
Old Jun 28, 2003 | 02:01 PM
Not be take this totally OT, but yeah, its been the same here....campaigning our car in ITS and running the shop has left me with zero social life and no time to do anything...but, dems da breaks I guess.
Ideally, you do want the fuel pump upgrade with the cam IMHO, and yes, the idle with the 272's will be on the lumy side.
As for getting the HKS cams, its not hard at all actually...places like AMS, ourselves, and a few others can easily get them for you, in your choice of lift as well (since HKS does different variations on the 262/272 cams
Martin - which ones are you guys using right now?
