What is the LARGEST BOLT-ON turbo available for an Evo VIII / IX?
Old Jun 30, 2007 | 06:43 PM
fromWRXtoEVO's Avatar
I know that it might sound irrelevant but it might also sound interesting. FP offeres the same turbokit for the Evo as for the 2 Gen.
The FP3065 is offered by Buschur and also by Forcedperformance, it is the same turbo but for the Eclipse application the FP3065 bolts on directly to the stock exhaust manifold while on the Evo 8 you need a custom exhaust manifold.
I thought I brought this topic up because given the same conditions, the 2 DSM gets a few bolt-on turbos bigger than the LT/Green while being almost an identical engine as the Evo. Weird uh?
My point is that it is indeed very possible and doable to build even bigger turbos than the LT/Green that bolt on into the Evo's 4g63, they are already available for the 2G DSMs
Carlos
Old Jun 30, 2007 | 10:34 PM
_EVOlved_'s Avatar
Good insight...
So youre saying if I got a 2G manifold, that will allow me to have more options for a direct bolt-on?
Old Jun 30, 2007 | 10:36 PM
vboy425's Avatar
to answer your question, i must ask "how big is your bank account" ???
Old Jun 30, 2007 | 11:22 PM
ries's Avatar
Originally Posted by _EVOlved_
Good insight...
wouldnt work, the dsm mani would make the turbo face the wrong way...
Old Jun 30, 2007 | 11:27 PM
AWDBus's Avatar
Thats right, thats where the HAFE cast manny comes in. But for just a bit more then a green you can have the 3065 and all that is required is to pull the manny with the turbo.
Old Jul 1, 2007 | 08:28 AM
_EVOlved_'s Avatar
So all I would need is the manifold and that turbo will bolt DIRECTLY on??
Old Jul 1, 2007 | 10:09 AM
Nuked's Avatar
Don't forget you will have to fab up an o2 housing to attatch to your downpipe. I am prettysure that the stock o2 housing will not bolt up to the turbine housing of the 3065. Even if it did for a 2g model, I would think it would put the o2 housing facing right into the radiator due to being "backwards".
SQ
Old Jul 1, 2007 | 11:33 AM
_EVOlved_'s Avatar
True.
Thats kind of why Im going to stick with a 100% bolt-on...
Old Jul 1, 2007 | 08:27 PM
kouzman's Avatar
well i remember that some guys with the ATP 3037s (3076R) made 420-425whp on pump and close to 500whp on racegas or meth at around 28psi...
This turbokit is 100% bolt-on, can become less laggy if port matched, its a complete kit, you would only need injectors, if you already have other supporting mods like fuel pump, exhaust, mbc...
I think for the cost is one of the best deals. And when you save enough money you can always buy a t3 hotside and tubular manifold and use the big snail at its full capacity...
Old Jul 1, 2007 | 08:40 PM
evoracingstar's Avatar
either get a 20g or fp green pretty much the same turbo. bolt on turbo yeah u can pretty much bult on even a 35r but u would need to do injectors ect. but with the 20g and fp green i belive u can run on stock injectors with meth and 93 on that turbo u should be lookeing around 28 to 30 psi. u got evo 9 right?
Old Jul 1, 2007 | 09:08 PM
inco9nito99's Avatar
Dom, bud, get a 20G and we'll make some serious power, once AGAIN :-D
Old Jul 1, 2007 | 09:16 PM
alan678's Avatar
FPEVOGreen FTW!
Old Jul 1, 2007 | 09:21 PM
Evo9Kid's Avatar
20g
Old Jul 1, 2007 | 11:39 PM
_EVOlved_'s Avatar
If the price is right bro
420a-t
Jul 16, 2010 06:27 PM
Ludikraut
11
Feb 27, 2008 05:30 PM
ZerLp
Nov 10, 2007 08:07 AM
Racer24x
Lancer Engine Tech
Apr 30, 2007 04:11 PM
RS2
17
Feb 9, 2003 03:16 PM
