93oct vs 93+100%METH VS 100oct+100%meth VS C16 racegas ??
Well, from what Ive seen, the meth cars on 93 make comparable numbers to the C16 cars, however they are usually behind, but not by much. I think it comes down to setup. I feel like an FP GREEN car with 100octane+meth could match C16 numbers however a GT35R at 35psi lets say, the C16 would still reign supreme. I have nothing to back that theory up though
Your larger cams will help you, get an intake manifold and make sure you are running the .82 A/R hotside and I see no reason why with 30+ psi and c16 500whp is doable on any normal reading dynojet.
People have made well into the 5's on this turbo, it's definately capable of it you just need all the right parts.
Scorke
The reason why with a green vs a 35R that you get similar numbers out of meth as you do c16 is because of meth's impact on the intake air temps. Since your blowing a lot of hot air the amount of aid the meth does in terms of coolling vs the extra energy contained in the 117 octane is much more beneficial, whilst when boosting 30+ psi with a 35R I am sure the 117 offers more than the METH.
$ for $ if you have the ***** and the failsafes meth is a great investment, but with C16 you never have to worry, if something breaks or goes wrong it was going to happen anyway...
Scorke
robos4
Evo X Dyno Results
Jul 29, 2017 01:48 AM
tscompusa
Nov 19, 2015 02:36 PM
TTP Engineering
Jan 26, 2010 04:56 PM
