sick of forge bov flutter??
Old Jul 16, 2007 | 06:50 PM
evobeatsti's Avatar
i was too but i felt that i was stuck with the buschur uicp that was flanged for the forge 1g dv. i was wrong though, if you go to dejontool's website they sell a 1g adapter flange. buy that and get some silicon hose and couplers at your local autoshop and you can fit an ix dv onto your buschur pipe!
here are some pics of the setup...
hope this helps some of you out there!
Old Jul 16, 2007 | 07:42 PM
EVO8LTW's Avatar
Thanks!
Old Jul 16, 2007 | 07:46 PM
TURBevO8's Avatar
Is your MBC hooked up to your bov/intake mani line? I cant tell from those pics (too dark).
Old Jul 16, 2007 | 10:55 PM
john blaze's Avatar
does flutter reduce power?
Old Jul 17, 2007 | 07:05 AM
scheides's Avatar
EvoM Moderator
No, the flutter is just ffing ridiculously annoying. I switched to a Greddy RS and just had a new flange welded on my BR UICP. I like the IX/MR bov route though. How much boost are you running? Is it leaking at all?
Old Jul 17, 2007 | 07:32 AM
cfdfireman1's Avatar
While you're on the Dejon site get there stop leak kit and the stock diverter will hold a hella lot o boost and flutter even less.
Old Jul 17, 2007 | 07:56 AM
EVIL_EVO_VIII's Avatar
The flutter on my Forge bov is the most annoying thing ever.. Drives me nuts
Old Jul 17, 2007 | 09:56 AM
EVO8LTW's Avatar
I have the 1G valve with the leak stop kit and it does seal tight under high boost and doesn't flutter at low boost (typical street driving), but it isn't very smooth at releasing at high boost and causes some of the same issues as an aftermarket valve when you are driving at part but heavy throttle, high RPM, near full boost. No one drives this way on the street, but if you are autocrossing it is an issue I am finding.
Old Jul 17, 2007 | 12:34 PM
ok
The only time I have any flutter is right at the point it kicks in 15-PSI, high boost release is not a problem nor is low boost performance. I think for autocross or track driving there is always going to be some compromise and this is the best setup I've found.
Old Jul 17, 2007 | 01:40 PM
EVO8LTW's Avatar
Have you compared to an Evo IX or unleakstopped 1G?
Old Jul 17, 2007 | 01:47 PM
bluebyu36's Avatar
evil are u running the forge rs?
Old Jul 17, 2007 | 09:34 PM
HmanEVO's Avatar
I used to run the dejon leak stop kit on my GSX and had the same issues you were describing. During heavy throttle where boost would hover above the 15psi switch point of the pilot valve, I would get a little flutter and slight bucking whenever I'd back off the throttle. Now I use a tps signal to control the 1g bov seal point and couldn't be happier.
An alternative to the pilot-op pressure valve included in the dejon leak stop kit would be a wot switch that activates a 3 way solenoid. Works similar to the dejon leak kit. Only with the wot switch/solenoid, the bov will perform like stock under most conditions but at wot it would seal shut. Doing it this way gets rid of pretty much all of the driveability problems but you still get the benefits of a leak free bov during wot.
Old Jul 17, 2007 | 10:39 PM
evobeatsti's Avatar
i run 24 psi and have no leakage problems at all and no i dont think my mbc is on the same line as the bov but i am not sure sorry
Old Jul 18, 2007 | 03:26 AM
EVO8LTW's Avatar
Sounds great, but I'm not sure how to implement what you are talking about. Can you point to an example of a 3-way solenoid that might work? Thanks.
Old Jul 18, 2007 | 04:18 AM
JeffWels's Avatar
I had the same bucking/flutter issues at certain throttle inputs on street driving even trying to avoid the problem at all costs.
In the end I tryed the forge recirc valve, blitz dd valve, hks ssqv, then the aps dual drive recirc valve. ALL except the APS fluttered as bad or worse then the previous. The APS has not bucked my car once at no matter what throttle input I give it and it holds perfect boost.
Just an fyi instead of spending more money on switches and solenoids give an aps recirc valve a try.... you will be VERY happy you did. I spent way to much time and money figuring out I should have had the APS in the first place.
