All Evos whine a little right?
Old Oct 31, 2010 | 02:17 PM
eron28's Avatar
pretty much we experienced it all,,,i think its normal...
Old Oct 31, 2010 | 02:21 PM
meckert's Avatar
Originally Posted by JohnDoe1984
It wines like a 7 year old kid in 1st gear. Isn't first gear straight cut like a lot of reverse gears? It sure sounds like it.
BINGO...you win! Gear is straight cut
Old Oct 31, 2010 | 04:23 PM
GG06MR's Avatar
I'm on my 2nd IX MR, and like all other Evo's both of mine had/have their share of minor squeeks and rattles depending on the temp and/or road surface, BUT I have never heard a whining noise in either of my Evo's in any of the 6 gears. However, my 2nd one does have that random metal scraping noise coming from behind the timing belt cover that seems to be pretty symptomatic with the IX's, so I guess it's like 6 of one, or half a dozen of another. Yay Mitsubishi.
Old Oct 31, 2010 | 05:18 PM
TommiM's Avatar
I had that similar whine in 1st and 2nd gear when driving at parking lot speeds when I first got my evo. I changed out fluids to some fresh diaqueen with no change. After I swapped that out for amsoil it went away. Never hear that noise again. Mine was more on decel/coasting in 2nd though ~10mph
Old Oct 31, 2010 | 07:09 PM
ALSTAR's Avatar
You'll get used to it after DD for 2 weeks or so
Old Nov 1, 2010 | 05:38 AM
sirsol's Avatar
Mine has whined since new in 1st and 2nd gear, then immediately shuts up when you go to third. 82K miles and hasn't blown up yet (knock on wood), so you'll be ok. T-case failure is very apparent, I had mine replaced under warranty at around 40K miles and when it went bad, I immediately knew. You'll get a loud whine that gets progressively louder with speed. If you don't have that, you're fine.
Old Nov 1, 2010 | 03:25 PM
evo8426's Avatar
ive never heard a 9 whine but out of the 4 8's ive been in they all make a whining noise in the lower gears
Old Nov 1, 2010 | 06:46 PM
zac5's Avatar
cssaddictm4, what happened?
op, can you tell us is it whine from drivetrain or powertrain?
Old Nov 1, 2010 | 06:50 PM
MitsuJDM's Avatar
I have 1st/2nd gear whine, slight decel whine in the 20-50mph range and a very very very faint whine on the highway. It's been that way forever and I'm convinced, after owning two Evo's ALL Evo's own a little bit. My fathers MR also has a slight whine on the highway.
I've worked on Evo's with the death whine, it's unmistakable.
Old Nov 1, 2010 | 07:05 PM
killerpenguin21's Avatar
my 9 whines at accel or decel in first, not in any other gear. it had a little 2nd gear low speed whine, and overall very noisy drivetrain which i thought was normal when i bought it 2 weeks ago... till i changed the fluids (had 25k on them) last week and it made a drastic change.
Old Nov 1, 2010 | 07:52 PM
ZensokuEVo's Avatar
is it me or is there a lot of whining noise posts..i'm experiencing some whining too..hope you figure it out
MattC28
11
Nov 25, 2010 06:45 PM
kidkayos
Mar 12, 2010 01:58 PM
Boostin4g63
13
Mar 16, 2008 10:22 PM
TurboIX
17
Jul 14, 2007 05:38 PM
TeStUdO
14
Jun 30, 2006 08:11 AM
