how do i get this o2 housing gasket off?
Insert a thin, flat blade screwdriver between the gasket and the housing and work your way around the circumference of the thing. Then, once there is a bit of space, go back with a wider flat head screwdiver.
+1- If you can manage to cut a slit up one side of the gasket by using a screw driver, you should be able to just grab it with a pair of needle-nose pliers and pry it off. Make sure you are wearing eye protection if you are underneath the gasket pulling at it..metal fibers and eyes don't mix (sorry about the mom-sounding rant).
EVO.C
10
Sep 26, 2012 07:13 PM
