Greddy oil filter block adapter safe for engine?
Old Jul 23, 2007 | 11:51 PM
DimitrisIX's Avatar
I just bought the greddy oil block adapter for my evo ix. I did search for topics on this and some people said that it might require a smaller oil filter in order to fit the engine undertray. is this correct for the IX?
Also is this adapter safe for the engine? i.e. does it block the flow of oil or reduce oil pressure?
thanks
Old Jul 24, 2007 | 03:57 AM
mump's Avatar
smaller filter as in the OEM short evo filters not the long one like fram, etc sell. i have had my greddy adapter on for 2 yrs, no problems.
Old Jul 24, 2007 | 09:09 AM
hokiruu's Avatar
are you referring to the remote mounting kit? if so, don't waste your money. it's pretty cheap, has weak little hose clamps that break easily if you try to crank them to any reasonable tension. it does raise your oil capacity slightly though, and makes the filter easy to access, although i think that the stock location is extremely easy to access already and is fine. if you are determined to use an aftermarket oil filter sandwich, use a Mocal or something and use all AN fittings. stock or that are the only two ways to go. but adding rubber hoses and clamped fittings to your oil system is stupid if you can avoid it.
Old Jul 24, 2007 | 09:14 AM
TURBevO8's Avatar
Honestly man I would sell that thing and just get the 42 Draft designs adapter to replace the one plug by the filter. I did and zero leaks and you can use the stock filter which is a good thing IMO.
Old Jul 24, 2007 | 01:19 PM
Luis@TTP's Avatar
becareful when running over things in the road if its lowered because it runs the filter about a inch and a half lower then factory
Old Jul 24, 2007 | 05:15 PM
DimitrisIX's Avatar
thanks guys
Old Jul 24, 2007 | 05:30 PM
Cirrusly Evolvd's Avatar
I would definitely return that item if you can. I used it and it was a $700 mistake. I was using the Greddy adapter and a K&N filter while driving on the surface streets of north Chicago. A frost heave reached out and touched me by ripping off my oil filter, breaking the oil filter housing and keeping me in Chicago for another 3 days.
I have since went with the 42 Draft Designs adapters and the oil filter is nice in cozy back up at stock height.
fsc0224
Mar 14, 2013 06:50 PM
EvokidIX
Feb 23, 2011 01:59 PM
Inprogress
26
May 13, 2010 01:17 PM
newbiewonkenobe
Aug 19, 2006 07:57 AM
LateSleeper
Apr 9, 2005 11:25 AM
