intake manifold
Old Sep 10, 2007 | 01:27 PM
  #61
Buksh's Avatar
Originally Posted by atlvalet
You said you switched to the BR unit. What do you need help with?
I need help with the intake manifold.
Old Sep 10, 2007 | 02:15 PM
  #62
PPI's Avatar
PPI
I have a core to start from if yours is still on the car
Old Sep 10, 2007 | 06:12 PM
  #63
richysevo8's Avatar
Ams Vsr
Old Sep 11, 2007 | 11:06 AM
  #64
Buksh's Avatar
Bump anyone
Old Sep 11, 2007 | 11:18 AM
  #65
2003lancerevo8's Avatar
Well my thoughts are this, the VSR intake is BEAUTIFUL, I have had one on my car for 2 years and it still looks beautiful. With you adding a 2.3 liter you will make up for the torque loss and gain the top end which is what the VSR gives you.
On big turbo's the VSR is awesome, I only had a 50 trim and it added a huge amount of gains for me anyway.
It's all about what you want, you are going to have the AMS lovers and the Buschur lovers,
They are both proven to work however from what I understand and have read the VSR will give you more top end.
Old Sep 11, 2007 | 11:31 AM
  #66
Erik@MIL.SPEC's Avatar
If you're running a big turbo and stroker, I don't see why you wouldn't go with the AMS intake mani.
Old Sep 11, 2007 | 11:42 AM
  #67
Vostok 7's Avatar
Even though the Weapon R has some quality issues, for those who are trying to get every last bit of power out of their stockish-turbo set-ups might want to consider it. The plenum is smaller than the other aftermarket intake manifolds, and in the data I've seen the car both gained power from 5500rpms+ and saw lower boost (engine breathing better). This was with HKS 272 cams and a stock-based turbo.
LINK TO POST W/ INFO:
https://www.evolutionm.net/forums/sh...51&postcount=5
Was that on one of the old style ones? They seemed to have changed their style and the new one looks 1000x better than the old one. I'm considering the WR Intake Manifold but they've always seemed like a crappy ricer company to me. Seems like they've come up in the world, though.
- Patrick
Old Sep 11, 2007 | 12:03 PM
  #68
fostytou's Avatar
EvoM Community Team
Originally Posted by crcain
What didn't you guys like about the Magnus?
I heard AMS used to use a Magnus manifold on there demo car. This sort of swayed me to believe Magnus had been on the market longer building intake manifolds.
Magnus has had a manifold longer than AMS, however that doesn't mean that it is better (in design or final product).
Old Sep 11, 2007 | 12:13 PM
  #69
- Patrick
I assume it was one of the old style ones. The WR bolts right up to the stock piping. I am not sure if the Magnus does or not.
Old Sep 12, 2007 | 04:25 AM
  #70
vboy425's Avatar
AMS VSR you will loses power, unless you have biggy like 3076R and up. on the other hand the WR and MAgnus bolt right on. Except the WR is a POS. it will crack. I do a lot of big road course racing. The the cheap *** Chinese made WR cracked on me. As for my Magnus, it have been working perfectly so far.
Old Sep 12, 2007 | 02:01 PM
  #71
Buksh's Avatar
Well for starter i would be running a GT37R and a 2.3L JAM Short Block. Hence the post.
Old Sep 12, 2007 | 02:07 PM
  #72
dxbevo9's Avatar
i went with the AMS VSR..although i am still running the stock turbo...
i made this decision after a friend of mine with the same setup gained about 28hp and sustained a better power curve through out the power band...he is also running the stock turbo...
however we both opted for the stock throttle body
Old Sep 13, 2007 | 02:18 PM
  #73
kduncan01's Avatar
How long have you have the Magnus manifold installed?
What is the power difference like?
Thanks
Old Sep 13, 2007 | 02:20 PM
  #74
kduncan01's Avatar
What other mods does your friend or you have?
Was any power lost on the bottom end?
Thanks
Old Sep 13, 2007 | 02:30 PM
  #75
I had the VSR on my car from when the car was an all bolt on stock turbo through the 50 trim and the 2.0 and then to the 2.3.
This intake will not let you down, especially when you are running a 37R...... It will give you the most up top since I assume you are drag racing the car.
I don't think you are going to lose as much as everyone is making it out to be.
Maybe you should contact AMS and Buschur and do back to back testing with your car.......
