EVO GREEN & 2.3 STROKER 352awhp & 358tq
Old Jul 29, 2008 | 09:05 PM
  #151
JMB8606's Avatar
well a little update. I still have the car and its getting retuned this week by REESE Tuning. only changes were a 3 port boost solenoid vs the MBC I had.
Old Aug 2, 2008 | 03:33 AM
  #152
Shocky's Avatar
keep up the good work.. there's room for more
Old Aug 2, 2008 | 10:33 AM
  #153
evoPirate's Avatar
Good luck with the retune! Make sure and post results
Old Aug 2, 2008 | 11:29 AM
  #154
JMB8606's Avatar
355hp and 380tq. only mod changed was the gm 3 port solenoid.
Old Aug 2, 2008 | 12:11 PM
  #155
mudduck's Avatar
^^^ torque came up nicely... at what boost? still on 91 gas? do you have the graph to post up?
Your torque numbers are now proving that you have a 2.3L under the hood
Is a meth kit totally out of the question for you?
My Green starting waking up at like 25+psi... I spike 28psi daily on pump 93 with 75%/25% meth/water and drop to like 24 at redline (was tuned for spike of 29.5psi, but scared to run this daily, due to weather fluctuations possibly causing knock)
I will say this: ever since I started running meth, I beat on the car less than when it was on pump gas, because I always have it in the back of my mind that the meth kit may malfunction and blow the engine.
Old Aug 2, 2008 | 12:28 PM
  #156
JMB8606's Avatar
it was on the 91 oct. 24psi
I'm trying to sell the car.
meth is probably out of the question because I to would worry about the meth kit failing.
I dont have the graph but I will see if the tuner can send it to me
Old Aug 2, 2008 | 12:34 PM
  #157
Duh Panda's Avatar
lol!!! whatre you doing with a 2.3 on a green?
theres several things that make me want to push meth... there are quite a few good failsafe kits out there... im thinking of using Tephra's patch that ll swap your ECU map to a a safer non meth map once it recognizes that the meth kit has failed
Old Aug 2, 2008 | 12:38 PM
  #158
mudduck's Avatar
What are you looking at buying?
Old Aug 2, 2008 | 12:45 PM
  #159
Kemist's Avatar
Are you running a test pipe or hfc? the only reason I ask is that my first dyno was very dissapointing at 286hp, should have been more like 350 according to my tuner. Once things were looked at, my HFC was a melted brick and my exhaust mani had a grand canyon sided crack in it-- I put a test pipe in and a new mani and she is a different car. You probably checked already, but just in case. good luck
Old Aug 2, 2008 | 01:00 PM
  #160
JMB8606's Avatar
i looking at buying a beater. im running a test pipe. there is no problems with my car. the stock intake box and maybe my stock piping is robbing some power but I like the stock looking engine bay. Im in cali
Old Aug 2, 2008 | 05:31 PM
  #161
Smogrunner's Avatar
boost was 21psi. 91octane. I bought the car used and never had it dynoed before.
Compression was tested 8 months ago. 190 across the board.
The previous owner said it made 340hp and 307tq. same dyno
mods were same as above except
2.0 factory block
9.8 hotside
stock o2 housing
software XEDE with Smart
no port work
I assume 91octane 23psi.
I was disapponited because the car did make great numbers with the 2.0 and evo 8 turbo. And if you compare the numbers to the old setup to the current numbers= no such good improvement
r3d d3v1L
Feb 19, 2017 03:42 AM
evo8vz
Feb 13, 2017 11:35 PM
evo8vz
Oct 23, 2016 11:06 AM
SOLIDEVOX
Cobb AccessPORT
Feb 3, 2015 03:33 PM
saltydog
Nov 5, 2011 12:22 PM
