GT30 and GT35 Guys
Old Jul 29, 2007 | 02:57 PM
ant_turbo's Avatar
GT30 and GT35 Guys
Hey quick question I have a GT30R/BB and now when I launch I have to slip the clutch alot more then with my stock turbo,,,So what do you guys have your 2step at?? THANKS,, (my 2step is @6000)
ACT/HDSS CLUTCH..
Old Jul 29, 2007 | 04:10 PM
cssaddictm4's Avatar
ACT/HDSS CLUTCH..
2step at 6500rpms, building boost to 16psi then a quick slip of the clutch and then full release. Hold on and 2nd gear comes way to fast.
Old Jul 29, 2007 | 04:33 PM
AlwaysinBoost's Avatar
with the 35r I had my stationary rev limiter set to 5800 RPM. with a quick slip of the clutch it was good for mid 1.7s on all season tires. Once and a while the rear end would slid out on the launch but the front wheels would pull the car straight. YRMV.
Old Jul 29, 2007 | 05:02 PM
steelcityevo8's Avatar
had my 2step at 6k then moved up to 6.4k still have not found the sweet spot gettin wheel hop but did get quicker at 6.4k, track conditions and vehicle setup play major role in all of this , obviously
Old Jul 29, 2007 | 05:07 PM
ExViTermini's Avatar
watch that wheel hop, with the power your making you will break **** in a heartbeat. I prefer not to use a 2step usually, just rev it to about 75-8k and then come out on the clutch, is usually a little less shock on the drivetrain and comes out of the hole just fine with the right clutchwork.
Old Jul 30, 2007 | 01:00 AM
ant_turbo's Avatar
So is 6500 safe?? I also see in your SIG new tranny on the way!! What happen there?? THANKS....
Old Jul 30, 2007 | 06:10 AM
LoL, 6500 is fine IMO. The broken tranny would be from a combination of things: ACT Clutch (even when adjusted) causing gear lockout, I was told this caused most of the issues. Driver error of pulling out of third before the clutch was fully engaged.
EDIT: I was also pushing the limit of the ACT clutch with 400ft/lbs of torque. It was my error in installing that clutch on my setup, I have been told numerous times that I should have had a twin disc. Which now on my new setup I have a Carbonetics Triple disc.
Old Jul 30, 2007 | 06:15 AM
WrX Kila's Avatar
2 stepping with a big turbo like that at hi RPM's= $$$$$$$ spent repairing drivetrain.
Old Jul 30, 2007 | 09:18 AM
vwjeff's Avatar
I was at 5900 rpm with the stock turbo making 16 psi off the line.
With the 35r I am at 7100 rpm and 16 psi.
Old Jul 30, 2007 | 10:16 AM
MRadjahoe's Avatar
Not if you know what your doing! Ive done it several times on the street and the strip without breaking tranny parts. Rev set @ 6500rpms... oh yea. You MUST SLIP the clutch.
zenoise
35
Oct 11, 2012 07:01 AM
BootScraper88
29
Aug 22, 2008 07:51 AM
mandy1
Nov 25, 2007 07:22 PM
3000ways
23
Mar 9, 2006 01:12 PM
Yaroslav
Jan 31, 2004 12:39 AM
