Aem Wideband (where to run the wire from the O2 sensor)
Old Jul 29, 2007 | 07:52 PM
the1andonlyE's Avatar
Where would be the best place to run the wire from the O2 sensor to the inside of the car. Is there a place I could run it from the bottom of the car or would I have to run it to the engine compartment through the firewall? Any help would be appreciated. Thanks in advance.
Old Jul 29, 2007 | 07:56 PM
03evoyellow's Avatar
if you look under your car there are groments. Atleast on the pass side i plan on running mine that way the cord is plenty long enough.
Old Jul 29, 2007 | 08:17 PM
Can you tell me exactly where they are and will I have to take out the seat or the carpet?
Old Jul 29, 2007 | 08:31 PM
EVO8TOR's Avatar
run it through the same hole the stock o2 sensor runs in.
Old Jul 29, 2007 | 08:53 PM
Thanks for the help guys
Old Jul 30, 2007 | 06:48 AM
scottatyamaha's Avatar
I ran mine under the dash and over to the passanger side then I pulled up the carpet on the passenger side floor board and there is a rubber plug there that i pulled out and ran the wire for the sensor through. It hardly fits through the hole but it will with some work. Also you have to remove the center consol in order to lift the carpet up to do this. It is very easy though.
Old Jul 30, 2007 | 08:26 AM
8thWonder's Avatar
I took the passenger side seat out to have plenty of room. Just four bolts to remove and it's out.
Old Jul 30, 2007 | 02:22 PM
Thanks alot guys I dont know what I would do without you!!!!!!! THANKS!!!!!!!!!!!!
Old Jul 30, 2007 | 02:40 PM
revvin9k's Avatar
I ran mine through the grommet under the drivers seat, and just zip tied it to the lines.
GL.
Grendelrt
Evo X How Tos / Installations
28
Jul 9, 2015 11:39 AM
wazmunstr
Jan 29, 2013 06:12 PM
sioux90
Nov 16, 2010 09:30 AM
93civEJ1
20
Jun 8, 2007 09:03 PM
SwiftEVO
10
Jun 7, 2007 04:47 PM
