Full-Race Twinscroll 35R
Old Nov 22, 2007 | 01:43 PM
  #331
johnd's Avatar
Originally Posted by Mark S
I will agree with you here, I have tried a 4094 against a 4088 on a Ford YB cosworth engine and the 4088 was so much better everywhere than the 94,My engine made 30hp more on the 88 and no surge,
This is the main reason I brought a 4088TS kit from you for the Evo engine I am doing
Mark
Watching with interest on that one Mark. Have my GT40 kit and just waiting on the Cosworth stuff to arrive.
When do you see Jon's being ready for the dyno?
cheers
John
Old Nov 22, 2007 | 02:44 PM
  #332
mymigi's Avatar
Sorry, just want to suscribe to the thread, very interesting...
Old Nov 22, 2007 | 04:46 PM
  #333
CBRD's Avatar
Geoff,
i do have ams 30R plots and my rnr and ams 35R plots... on a 2.0 and 2.3
and...
here is a sneak peek of our setup from the front.. all i will release for now...
similar to yours... but shorter piping even just barely
great minds think alike.
cb
Old Nov 22, 2007 | 04:55 PM
  #334
MuslimEvoFreak's Avatar
Vertical front mount ftw!
Old Nov 23, 2007 | 01:16 PM
  #335
JKav's Avatar
Originally Posted by Full-Race Geoff
these are 84.5mm B18s, so the displacement is right about 2.0L. They have huge cams and solid headwork, revving to 10K rpm.
what do you think about the 2JZ supra (3L) and 4094R?
In that case forget what I said before. With those B18s you're on the map but not approaching the limits of either the 88mm or the 94mm wheel. Even by redline. The 88 will have the edge in powerband, for certain, since the 94 has a kink in the surge line and is working against a more significant wheel mismatch.
The part that doesn't make any sense at all is that you measured higher IATs with the 94 ?? If those B18s are breathing as well as they ought to be then the 94will be turning out LOWER discharge temps than the 88 from around peak power to redline (there is a small efficiency advantage to the 94mm comp wheel in this regime... ). That is very strange...
Also have you measured exh b/p on any of these engines?
Shoot me some specs on the 2jz--boost pressure, redline, amt of headwork, type of fuel etc
Old Nov 23, 2007 | 01:43 PM
  #336
EvoEntropy's Avatar
Has there been any results on the twin scroll gt35r?
on a 2.0L?
Old Nov 23, 2007 | 05:36 PM
  #337
Max Power's Avatar
I don't think so yet... I know evodan2004 is going to do some testing pretty soon. I think a lot of people are waiting for "someone" else to test the Turbonetics GT35 sized turbo - unfortunately it's a t4 flange so that leaves most of us gt30 guys out. However some 1.06 t3 housings have become available so I think that's what people will be testing. I have one stored up for the future - I will be building a gt35 or possibly an hta off of it and seeing how it does. I was going to wait until I went with a stroker - however seeing how my current setup does, I don't think the spool would be that unbearable with a 2.0.
Old Dec 2, 2007 | 01:35 AM
  #338
scherejs's Avatar
Just bumping this up to hopefully see some results.
Old Dec 2, 2007 | 07:57 AM
  #339
EVO Tweeker's Avatar
+1 for results
Old Dec 2, 2007 | 11:34 AM
  #340
High_PSI's Avatar
Yeah WTF MaTE!?!?!?!
Old Dec 2, 2007 | 12:14 PM
  #341
Turbo Kyle's Avatar
Its crazy no one really has any numbers put up for this kit.
Old Dec 2, 2007 | 12:22 PM
  #342
Jasil's Avatar
I would love to see 4088R on a built setup pushing 38-40psi, but until then I can't justify the price. I know what a 35R-HTA will do because we have graphs, dynos, and trap speeds, same goes for a 37R, we don't have anything on high boost from any of the TS kits except for the 42R.
Old Dec 3, 2007 | 09:14 AM
  #343
EvoDan2004's Avatar
ok guys. im heading to the dyno today.. i will make a new thread with
street logs
in cab shots of the boost and rpm on the street
dyno vids
dyno logs
dyno graphs
and some street fun.
wish me luck.
remember im doing a 30r the 35r will be after the 30r and will be done the same way so we can get some good comparison data.
Old Dec 3, 2007 | 09:34 AM
  #344
Ludikraut's Avatar
Please link to your new thread when you post it.
Can't wait to see the results.
l8r)
Old Dec 3, 2007 | 05:45 PM
  #345
Turbo Kyle's Avatar
+1
