What's the cause of CEL p0011?
Old Aug 6, 2007 | 07:09 PM
PurEvo's Avatar
It's really hard to tell. The trigger looks a bit different from each side. Dont mind the red dot. I used it to let me know how I had it before taking it apart.
If anybody can see the difference and know which side goes on the cam. Please inform me.
Attached Thumbnails What's the cause of CEL p0011?-t1-11.jpg   What's the cause of CEL p0011?-t1-2-22.jpg
Old Aug 6, 2007 | 07:22 PM
Ivan@AMS's Avatar
Look at the cup from the end and then the cam from the end. You will see the nubs on the cup are offset to one side of center. You will see the groove in the cam is offset to one side of center. Install the cup so offset is in the same direction on both the cam and the cup.
Old Aug 6, 2007 | 08:02 PM
PurEvo's Avatar
Ok, I see what your saying. Well since i have that installed correctly, what's causing me to throw the P0011 code?
Old Nov 27, 2008 | 09:04 AM
Psquared's Avatar
bump from the dead.....I got a clutch installed....and outta no where I'm throwing this code?? Any ideas? Maybe they damaged the electrical harness plug that plugs into the cas?
Old Aug 4, 2009 | 06:12 PM
EvoPlaya31's Avatar
any updates on this.. after chenging maps on my friend car i get this. i did a cams too tho but it was 500 miles ago and no code like this. just happen after i did some little tunning
Sheasta
Sep 27, 2015 07:52 PM
2006GSR
Sep 10, 2015 05:29 AM
atxMR
12
Oct 15, 2014 07:00 PM
EvOcHaRgeR
Dec 31, 2009 11:04 PM
stikillller
Jul 1, 2006 10:45 PM
