Solid Motor mounts - knock?
Old Sep 8, 2020 | 11:38 AM
thepoint4life23's Avatar
I have a stock Knock sensor.
Car would sometimes do it before the tune.
Put in bigger valves when timing jumped and motor mounts now its flashes at any amount of throttle even just trying to get to the posted speed limit at talking less than 10 psi/ Car is only on 18 psi right now and still will do it under full boost from time to time.
Would a small scratch on a piston make this happen?
Old Sep 8, 2020 | 11:45 AM
Evo8cy's Avatar
No, a small scratch would not do that. It is best of course the crown of the piston to be without imperfections. It matters not if you are on 10 psi or 100psi, if the tune is wrong, and I am mostly referring to the timing table in your case, could actually cause real knock.
Marios
Old Sep 10, 2020 | 05:13 AM
I guess i would call it a little knick. that has been polished down a little
Bob Evolved
Sep 30, 2011 12:36 PM
dudical26
Jul 15, 2007 06:01 AM
joeymia
Aug 4, 2006 05:27 PM
EVOONYOASS
AEM EMS
28
Apr 3, 2006 05:36 AM
