Getting a race gas tune, which fuel should I use?
Old Aug 25, 2007 | 07:11 PM
mcwop23's Avatar
Should i do a C16 tune or do something like a 100-104 octane tune? We have stations that offer the latter and it's easy to get. The C16 is obviously more difficult to obtain. Would a C16 tune be worth the hassle over a 100-104 octane tune?
Old Aug 25, 2007 | 07:13 PM
EvoDan2004's Avatar
im in the same boat. im wondering what makes more power.
93+100%meth
100oct+100%meth
C16.
its for a 30r turbo kit
what turbo kit are you running????
Old Aug 25, 2007 | 07:18 PM
mcwop23's Avatar
i am still on the fence about whether or not i should do meth, still getting info from people i respect. If i did do the meth thing then this thread would be pretty moot.
Old Aug 25, 2007 | 07:25 PM
EvoDan2004's Avatar
i have 93 and 100 sunoco on tap here 10 minutes away in a few directions.
all VP fuels also about 30 min away. so avalibility is no issue for me. it is for some though.
Old Aug 26, 2007 | 09:13 AM
mcwop23's Avatar
also I don't daily drive the car which is another reason i put toward not needing meth necessarily
Old Aug 26, 2007 | 09:21 AM
Ev0luti0n's Avatar
If you can afford the c16 then go for it, get the car tuned for c16 and have some fun....
And meth is really cool if you drive the car alot...
get the c16 and TURN THE BOOST UP!
Old Aug 26, 2007 | 09:27 AM
DynoFlash's Avatar
You should get a race gas tune on the fuel you intend to use and which is easy to obatin. Have a talk with your tuner about your intended driving style and set up and see what he / she recomends and is confortable with.
AL
Old Aug 26, 2007 | 10:48 AM
rr06rs's Avatar
I'd call up Wheeler automotive and get some 112 and get tuned on that. That's what I'm going to do. In jax, the best prices I've found are through them. 110 is $4.50, 112 is $5 and C16 is $8. To me, the 112 is the best value. Nice running into you the other day too. We'll need to get together some time.
Old Aug 26, 2007 | 02:14 PM
CO_VR4's Avatar
If you're still using a cat, etc., generally 112 is the highest unleaded octane fuel you can buy.
If you do not have a highly modded setup, C16 can sometimes actually slow you down, unless you're specifically tuned for it, and you might not get any significant improvements with C16 over, for example, 109 or 112 if your mod list is not long. The main value for higher octane is limitation of detonation at high boost levels. If the rest of your setup will not benefit as much from very high boost levels (or live with them ), then C16 is not incrementally useful for you. If you don't have a standalone, or if you're not doing your own flashes, and you are limited to one map, you should map for which fuel you will use all of the time.
Old Aug 26, 2007 | 02:29 PM
whitey4d's Avatar
Who makes 112 unleaded? The highest that Sunoco makes is 104 and I beleived VP to be the same. Never use leaded gas with a cat. Also know with a test pipe running leaded gas still kills O2 sensors. The higher the octane the faster usually due to the higher lead content.
Old Aug 26, 2007 | 02:38 PM
Turbo Kyle's Avatar
For some reason I have not seen alot of people run 110 Leaded....Im not sure if its my location (St. Louis) but I can get 110 Leaded all day long. If I get a race gas tune It will be with the 110....because its about 1/2 the price of C16
Old Aug 26, 2007 | 03:03 PM
mcwop23's Avatar
thanks for the suggestions guys
Old Aug 26, 2007 | 07:47 PM
CO_VR4's Avatar
If you're constantly using leaded, you'll also anticipate that you'll have to watch some of your sensors more carefully -- factory O2, wideband (if you have one)....
Old Aug 26, 2007 | 08:47 PM
Nuked's Avatar
I had pretty good success with C12. I ran 5gallons of C12 and 3gallons pump93. I will probably stick with this formula for race fuel as the C12 is cheaper than C16 and more avail.
SQ
Old Aug 26, 2007 | 10:50 PM
1slowevo's Avatar
anyone use the oxygenate 109? I have heard good stuff about it
tscompusa
Oct 25, 2012 07:13 PM
nj1266
Feb 21, 2008 01:34 AM
EVO8LTW
16
Aug 27, 2005 03:37 AM
evoland
Feb 25, 2005 11:41 PM
Smogrunner
Apr 13, 2004 09:26 AM
