cam gear question
Old Sep 3, 2007 | 04:31 PM
Mike.p's Avatar
cam gear question
i have fidanza cam gears zero'd out..i just got tuned on my aem..im running 10.5 hotside with 280's....my question is if i change my cam gears do its nesacary*(sp) to get re-tuned or should i be okay? i was thinking of going -2,-2..
Old Sep 3, 2007 | 04:39 PM
Robdevo's Avatar
Depends on how close your tune is to being lean. If you are fairly safe say, 11.0 flat accross the powerband, then I wouldn't worry about it.
Either way run a log somewhere safe say in 3rd gear.
Old Sep 3, 2007 | 04:42 PM
Mike.p's Avatar
yeah im running around 11.3- 11.6........do you think -2,-2 is a good setting or is there any other combos
Old Sep 3, 2007 | 06:24 PM
sparky's Avatar
What brand of 280's do you have?
Old Sep 3, 2007 | 08:10 PM
Mike.p's Avatar
hks
Old Sep 3, 2007 | 08:28 PM
sparky's Avatar
I really like the -2/-3 setting that TedB recommended. I've been with it for about 4 months and prefer it to my previous +1/-1. Are you still on the stock turbo?
Old Sep 4, 2007 | 01:53 PM
Mike.p's Avatar
i have the 10.5 hot side from 06 IX.........so is that -2 intake -3 exhaust?
Old Sep 4, 2007 | 01:57 PM
Mike.p's Avatar
^n.m i see your sig.............what kinda power incresse would i bee looking at...like i said i have hks 280's, megan manifold, 10.5 hotside, 02 housing, turbo back, fuel pump, bushur intercooler and piping, and tuned on a ems at 22 psi
Old Sep 4, 2007 | 06:17 PM
Gusl's Avatar
you need to do this on a dyno. Dont risk it!
Old Sep 4, 2007 | 10:16 PM
evilevo22's Avatar
what are the gains of cam gears if you already have cams. What deos -2-2 so compared to 0-0 thanks
Old Sep 5, 2007 | 10:05 AM
Mike.p's Avatar
^yeah im also interested to know
Old Sep 5, 2007 | 10:27 AM
Ted B's Avatar
Cam gears allow one to tweak the powerband wherever it's most needed. The cam timing settings that make best peak power differ from those that make the biggest midrange torque. It's primarily a matter of turbo size, driving style, additional mods, fuel, and tuning. Tuning cams is like adding a graphic equalizer to a sound system and finding the settings that sound the best to you.
Old Sep 5, 2007 | 02:32 PM
SWOLN's Avatar
Gonna Hijack here for a minute.
Hey Ted,
I'm curious to what you think about a cam gear on the a MIVEC engine? Is it worth it, should one just adjust via VVT map or both? My first thought is both, but I'm not sure what to change first and how each would effect the other. Thanks.
Old Sep 5, 2007 | 02:48 PM
Ted B's Avatar
If a cam gear is useful on a MIVEC engine depends entirely on the base timing of the (exh) cam. If I wasn't crazy about the timing of the exh cam (and I'm not crazy about it with some sets), I would set the exh cam gear where I wanted to position the LC, then construct my MIVEC map around that base cam timing.
Old Sep 5, 2007 | 02:53 PM
Ph3n1x's Avatar
Changing your Cam gears settings affect the VE. Contact your tuner for advice and also retuning after the change.
