CBRD new dyno record...
Old Sep 7, 2007 | 02:34 PM
  #46
kreionic's Avatar
Those logs are pretty crazy Chad. Like you said you pegged the 2 byte load. I wonder how much load you are actually making. Again awsome work. Keep it up
Old Sep 8, 2007 | 08:18 AM
  #47
CBRD's Avatar
is it bad that we are thinking of going up on the 2.3's displacement already? LOL..
yes its official...
cbrd has a sickness.....
stay tuned.
cb
Old Sep 8, 2007 | 09:20 AM
  #48
dsmfan95's Avatar
The only cure is more cowbell.
Old Sep 8, 2007 | 11:09 AM
  #49
CBRD's Avatar
LMAO..
i got a fever....
cb
Old Sep 8, 2007 | 01:00 PM
  #50
Zeus's Avatar
Good job with the OE ECU! Gives hope to the ever increasing majority who HAVE to use the OE ECU as the noose tightens around the majority of daily driven Evo owners necks. I know already in the major Metro areas of Texas you can't get your car inspected without passing the OBD-II read test. Also there is the ever increasing lobbying to make it a Federal statue.
Can't wait to see you break 500whp!
Old Sep 8, 2007 | 01:46 PM
  #51
Cali2MDevo8's Avatar
Registered User
Probably being broken right now!! Said he was going to work on it today.
j
Old Sep 8, 2007 | 01:56 PM
  #52
DS-03evo's Avatar
Are you using that hks dli2 you had on it before? It is blowing out spark with that on?
Old Sep 8, 2007 | 02:06 PM
  #53
RSGuy's Avatar
I can convert my speed-density AEM setup back to OEM ECU/MAF in less than 5 minutes...
Old Sep 8, 2007 | 03:30 PM
  #54
mchuang's Avatar
Well soon just think, you wont even have to change from AEM to OEM, because the speed density patch is coming soon!!! ahahha
Old Sep 8, 2007 | 07:21 PM
  #55
Zeus's Avatar
Sounds cool... but will it pass visual?
Then again, this is better served in PMs as I'm straying us off topic...
Old Sep 8, 2007 | 08:09 PM
  #56
vwjeff's Avatar
I think it looks pretty good for pump.
Old Sep 9, 2007 | 06:27 AM
  #57
CBRD's Avatar
thanks guys...
did some pulls yesterday, still in the 480-490whp range...
we are on the edge of being stupid at this point... so i may have to be happy with 499.7... but its still not 500. hee he.
we are running hksdli-2... we were having spark issues before, with all kinds of plugs and gaps etc.... we have hit 30psi now... without blowing the spark out...
we are running NGK br8eix non protruded tip iridiums.. they are at the stock gap (i beleive .26) and are working well.....
cb
Old Sep 9, 2007 | 06:35 AM
  #58
Ted B's Avatar
I know this sounds weird, but you may want to swap in a set of copper plug just for kicks and run the car again. It would be interesting to see if there is a difference (as some claim), and if so, you'd get your 500whp. I might mention that there could be a change in detonation threshold as well, so I might look for it before drawing any conclusions.
Just a suggestion.
Old Sep 9, 2007 | 06:39 AM
  #59
Spooldyou's Avatar
your car is pure sex.
Old Sep 9, 2007 | 12:56 PM
  #60
CBRD's Avatar
Just a suggestion.
Ted,
we were using coppers before... without much success in this motor... we used the 8's, 7's, etc... we had to gap them to .18 to keep them lit up over 24psi... car would break up regardless at 27psi...
but... we play with every little thing on the car.... so ill probably try again..
we are going to change to stock cams, dial them in... then some more basic cams, and dial them.. and see what happens...
and... well, maybe more displacement
cb
