Alky injection + checkvalve = BAD
Old Sep 6, 2007 | 01:09 PM
SlowCar's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=292953
Good info + good videos documenting the detrimental effects of a checkvalve in a WAI system.
Old Sep 6, 2007 | 04:05 PM
joehoo's Avatar
I just got the new check valve from snow, should I send it back?
Old Sep 6, 2007 | 04:51 PM
SlowCar's Avatar
nah, since u got it, just use it
Old Sep 6, 2007 | 07:04 PM
joehoo's Avatar
sarcaism?
Old Sep 7, 2007 | 04:57 AM
SlowCar's Avatar
not at all!
unless you got an alternative such as a...solenoid valve.
Old Sep 7, 2007 | 07:07 AM
EvoTech's Avatar
With no check valve. don't you run the risk of pressurizing the tank and potentially spraying meth all over a hot engine?
Old Sep 7, 2007 | 07:19 AM
Ted B's Avatar
Without investing a lot of thought into it, three obvious options to consider are:
(1) Use a check valve with a light spring tension.
(2) Activate the system at the onset of boost to prevent positive manifold pressure from purging the line back into the reservoir.
(3) Configure the system to trigger a solenoid valve simultaneously with activation.
Old Sep 8, 2007 | 04:36 PM
joehoo's Avatar
http://www.snowperformance.net/news_item.php?prk=30
this is the one, I just got in the mail from snow, what do you think?
Old Sep 8, 2007 | 10:34 PM
SlowCar's Avatar
Did you get a check valve or a solenoid valve
"Take a look and see why Snow Performance uses a free flowing, full stainless steel constructed solenoid while our competitors use restrictive check valves.
...........This new solenoid is so effective that it creates less than a 5 psi drop in line pressure!"
Will you be able to do this 2 test to see how much restriction there really is?
1 - pump -> nozzle
2 - pump -> solenoid valve -> nozzle
Old Sep 9, 2007 | 08:19 AM
joehoo's Avatar
solenoid valve, the one that snow just came out with. Snow's webpage isnt working right now, but its the solenoid upgrade...... So for any confusion.
Richard L
29
Sep 8, 2012 06:53 AM
IMPORTIMAGE
771
Mar 19, 2010 09:00 AM
SlowCar
Dec 31, 2007 06:53 PM
IMPORTIMAGE
57
Dec 18, 2006 08:25 AM
marksae
Dec 12, 2006 02:41 PM
