Has everyone seen the new coolingmist kit yet?
I think they just made everyones lives a little easier...
Vari-Cool Trunk Mount Kit. The worlds easiest to install and most advanced progressive controller kit. The controller is attached to the tank, so is the pump. Just strap it down. Pump is assembled with fittings and checkvalve. Just run the hose to your engine bay, install your injector (taps from the outside), give the controller power and ground and a boost hose source. Other kits on the market make you mount the pump, tank, controller...this kit makes that a thing of the past.!!
What do you think?
What do you think?
I am very interested but have a few questions:
(1) Who makes the pump and can this setup be used for both Alk & Meth?
(2) What failsafes are included with the kit?
(3) What is the size of the tank?
(4) What is the reliability of Coolingmist vs. Snow vs. TTP vs. SMC vs. Aquamist ?
(5) How much does the kit cost?
Thanks
Thanks
(1) Who makes the pump and can this setup be used for both Alk & Meth? and water
...its a coolingmist designed pump with shurflo
(2) What failsafes are included with the kit? low level indicator + clog nozzel detector. coolingmist also guarantees it wont fail.
(3) What is the size of the tank? 1.5 gallons
(4) What is the reliability of Coolingmist vs. Snow vs. TTP vs. SMC vs. Aquamist ? I've sold over 100 coolingmist kits without 1 coming back. they also offer 24-7 customer support and dave takes care of any provlems!
(5) How much does the kit cost? well pm me and i'll make everyone a special deal
Thanks
...its a coolingmist designed pump with shurflo(2) What failsafes are included with the kit? low level indicator + clog nozzel detector. coolingmist also guarantees it wont fail.
Thanks
www.importimageonline.com
Thanks
Thanks
Originally Posted by coolingmist
We are not a big fan of any of the "fail safes" on the market. Some are better than others.
Originally Posted by SlowCar
why not? because if they blow up, its not your car?
I did not say having a safety device is a bad idea. I am saying that I dont think any of the safety devices on the market are very good. Some are better than others, but all of them leave something to be desired. Having any of the safety devices on your car is better than none at all, of course.
Can you please recommend what additional failsafes should be added such that in the event of a variety of kit failures the engine will not be destroyed? Thanks
It would be really nice if a company put together a complete kit that had all the recommended / ideal failsafes so that these ALK / Meth kits were not thought of as ticking time bombs. I really want to run an ALK system on my car, but between weekly reports of 'problems / failures', incomplete failsafes, and the cost of a failure, I just cannot seem to justify the purchase.
Originally Posted by evodan2004
Dan,
I dont know who you are or what product this is in reference to. If you have a question about a product, please contact us through email and we will be able to answer anything for you. You can call our toll free number on Friday if you need live support as well. We will be more than glad to answer any support questions.
Thanks.
To cover most all potential issues that can require a failsafe in a meth injection kit many hundreds of dollars would need to be spent. Maybe even $1000+ not including the meth kit itself.
This is why many just take their chances instead.
TTP-Meth injection / Zeitronix combo covers MANY conditions such as "lean AFR", "high EGT", "low or out of meth", "leaks or power failure/pump fail". It will cost you however.
What do you think?
What do you think?
First let me say thanks for offering an interesting product. Now and with all my respect and without malicious intentions let me at least address a few arguable points.
What makes this controller the most advance?
What makes this kit the world easiest to install?
I am not trying to bring your product down but per say Buschur Racing launched a full truly bolt-on specific Evo kit. Your kit is more like generic, it is compact and innovative but by no means specific to the Evo.
I also see that having the controller fitted to the tank gives zero practical information while you are driving, in other words, ergonomically speaking is completly impractical (the driver has no direct visual contact with the controller)
Another issue is that you claimed this kit to be the worlds easiest kit to install, reality shows otherwise:
1) You still have to run vacuum/boost lines to the controller like other existing kits
2) You still have to run long power lines to accomodate the power source to the fuse box like other existing kits.
Depending on where this kit is to be installed it would determine how simple of complex the install is, either way in my opinion this kit is not easier than others. Sounds more like a sales strategy to me.
With that said I still think you guys have a interesting product. My summary is:
Highs
Good pump
Progressive controller
compatible alcohol/methanol pump (unlike old pumps)
Lows
Ergonomics (controller in the tank?)
Unsupportive fail safe policy?
installation average, not the easiest in the world
My .50c
Carlos
