Car DIED on way home lost all Spark..NEED HELP!
So recently installed a ignition amplifier.................Last week everthing was fine running perfect.......Coming home hit traffic for and hour.....Came out of traffic got up to 60mph and motoe died lost all spark sounded like coasted down the road...
Just got hom since leaving work at 5pm ....bro towed me with the RAM.....Checked all engine fuses....What else could be causing no spark.....Just know car tuens over and over and over knoe\w fireing up.....
Need help have big meet this saturday....
Just looked at the packs they looked fine......The manual on the ignition amplifier said even if went bad would still allow car to work...But I guess I should start there I am going to remove the ignition apm see what that does...
Mine took a dump while I was logging at idle. It sounded like someone stuffed a towel in the exhaust pipe. It just didn't sound like an evo. Disconnect amp, and put in stock coil wires. that should tell you if the amp is bad.
A strap wont mess up the TC? Sorry for the walk down OT street, but I thought it would mess up the TC. Good to know you can use a strap. Never heard of the Amp you have, but if you disconnect/disable it, and the problem goes away, it was that. If a coil is fried, you will be running on only 2 cylinders, and the car will NOT sound normal, either at idle or slight RPM's.
Your problem is the spark amplifier PERIOD. Take it off the car, and you will be OK. I said this 3 times already.
. What do you want us to say it is? Let us know,and we can say that.
. Your problem is exposed in the FIRST sentence of this thread.
"So recently installed a ignition amplifier".................
. Your problem is exposed in the FIRST sentence of this thread."So recently installed a ignition amplifier".................
