help on evo stock boost gauge
Old Sep 27, 2016 | 08:08 PM
Originally Posted by 2rbolag
Excuse the thread revival, saves from making another post relative to topic, but is it normal to read -30hg while at idle on the oem MR gauge? Always believed -20 to be ideal
Never really paid too much atten to vacuum pressure. I have an RS w/the same gauge. If you dont get an answer ill have to check this weekend
Old Sep 27, 2016 | 08:10 PM
2rbolag's Avatar
Thank you👍
Old Sep 28, 2016 | 06:25 PM
Thank you��
Took this pic today & was at 900-1K on the idle. Engine was not warm
Old Mar 10, 2017 | 12:50 PM
Tommyfacekicker's Avatar
Mines sits at the same spot as the one in the picture.
Old Mar 12, 2017 | 12:02 PM
WRC-LVR's Avatar
That converts to 16.5 in/Hg.. conversion factor is cm/Hg / 2.54 = in HG
When cold @fast idle the car will show about that and then when hot very close to 20 in HG. Mine does the same.... Timing drives it. When cold the ECU uses 5 degrees of timing and then once warmed up it uses 10 degrees or whatever is on the HO timing map at that rpm.
Old Mar 12, 2017 | 12:14 PM
4G63_EVO's Avatar
-30 seems like way too much
Old Mar 12, 2017 | 03:57 PM
I have cams so I get -18 psi of vacuum.
Old Mar 12, 2017 | 04:26 PM
4G63_EVO's Avatar
I got -14 to -16 on my s1s and -8 to -12 on my s2 but I asked for it very lopey lol
I didnt realize it was CM/HG seems pretty normal than.
Old Mar 12, 2017 | 09:16 PM
Nice. The power band must feel great up top
Old Mar 12, 2017 | 11:27 PM
4b11slayer's Avatar
My stock guage reads the same. Even though my map sensor sees less then -10 at idle. " Gsc S2".
Old Mar 13, 2017 | 01:12 AM
RightSaid fred's Avatar
It's because it's a metric gauge.
Look at the scale, it pegs out at 76 which is cm of Hg where a "normal" imperial gauge is in units of inches Hg (pegs out at 30ish).
76cm is close to 30 inches.
Normally you'd expect a vac reading of 18 to 20 inches (2/3 of an atmosphere) at idle. That would be about 50cm on that gauge.
as said above.
If it's reading zero at idle, it's because it's hooked up wrong. As in hooked up to the intake pipe before the throttle body.
Old Mar 13, 2017 | 02:16 PM
4G63_EVO's Avatar
as said above.
Yeah I noticed after that it was metric, but thanks!
Drsous
Jun 22, 2017 12:42 AM
nd_danial
Jun 17, 2017 12:37 AM
ineedboostman
20
Mar 29, 2017 12:38 PM
BTW_Evo8
Dec 10, 2016 09:00 PM
ralliart610
Apr 15, 2016 08:45 AM
