Some Pictures of my Open Dump 02 Housing
Old Sep 19, 2007 | 11:45 AM
  #46
dudical26's Avatar
Here is my mod list
https://www.evolutionm.net/forums/sh...8&postcount=76
I run a MAC solenoid which is controlled through the stock ECU. It is basically the same as the GM solenoid, only it is much higher quality and reacts faster.
I actually used to hold more boost but since I have done better exhaust and intake and all that my motor flows more air making it harder to hold boost at higher RPM's
Old Sep 19, 2007 | 11:54 AM
  #47
evolved83's Avatar
is your friend located in new jersey? and would he want to do another one?
Old Sep 19, 2007 | 12:04 PM
  #48
yellowEVO21's Avatar
steve - pm me if you want to know what it cost me - i got mine done at ics in CT.
Old Sep 19, 2007 | 12:06 PM
  #49
dudical26's Avatar
yes he is in northern NJ, I'll ask him about another one
Old Sep 19, 2007 | 12:07 PM
  #50
dudical26's Avatar
can you just post how much it cost please, for comparison.
Old Sep 19, 2007 | 12:21 PM
  #51
Cost was greater than $300....I dont' wanna say exactly how much cause they did it cheaper for me than what they said they'd charge everyone else since i was a test case.
Old Sep 19, 2007 | 12:35 PM
  #52
bigric09's Avatar
ouch... how much welding did they have to do ? it would probably cost me 20 plus the cost of the O2 here..... i just need better pics and need to see if there was any internal welding you had to do
Old Sep 19, 2007 | 01:01 PM
  #53
dudical26's Avatar
You have to close off the hole between the two chambers on the inside, other then that you are just adding another pipe onto the wastegate side.
Old Sep 19, 2007 | 01:15 PM
  #54
bigric09's Avatar
ok... that shouldnt be too difficult i wouldnt think, just some fabbing... and then making the pipe. Im going to start working on this. I will use my stock O2 as a template... thanks for the reply
Old Sep 19, 2007 | 01:21 PM
  #55
justchil's Avatar
make me one too while your at it
Old Sep 19, 2007 | 01:31 PM
  #56
bigric09's Avatar
lol... let me see how much work it will require and maybe something could be arranged
Old Sep 21, 2007 | 12:11 PM
  #57
Soon2BEVO's Avatar
The open dump setup WORKS. It will add power, especially torque when the boost hits. To have this mod done correctly though, you of course have to separate the wastegate chamber from the turbine exhaust chamber (common sense really), but Im sure some people would just cut a hole in the 02, weld on a pipe and call it a day.
Old Sep 21, 2007 | 04:16 PM
  #58
evolved83's Avatar
james i sent you a pm
that would be very much appreciated
Old Sep 21, 2007 | 04:28 PM
  #59
MitsuJDM's Avatar
Dudical26...will this work with an OEM LICP? Any idea? I'd be extremly interested in buying an o2 housing (eBay o2 housing?) and sending to your friend to do this for me. As long as it works with an stock LICP.... If not, well, I guess I'll just upgrade my LICP
Old Sep 21, 2007 | 05:07 PM
  #60
dudical26's Avatar
It will probably work with a stock LICP or any other LICP for that matter. But the fitment is going to be custom. You would really have to take the car to a welder to do custom work.
