HTA GT35R on an AMS kit!
Old Oct 2, 2007 | 09:28 AM
LT1runner's Avatar
Originally Posted by redevo58
Whats the main difference between the hta 35r and the regular 35r? From what i can see in the pics it seems that the only difference is the compressor wheel?
The compressor wheel is the turbo pretty much. There is the hotside, but even with the hotside being the same, the cold side wheel makes it different.
Old Oct 2, 2007 | 02:20 PM
Ross W's Avatar
The HTA looks quite interesting! Can DB confirm that the car had the same cams in before and after on FP graphs?
Old Oct 2, 2007 | 03:10 PM
binh's Avatar
looks like a killer setup. can't wait for some results
Old Oct 2, 2007 | 10:52 PM
Ross W's Avatar
Great idea for a satup
When will wou have some dyno results?
Old Oct 3, 2007 | 05:35 AM
LT1runner's Avatar
If everything goes right, it'll be this saturday. So sometime saturday afternoon, I should have the number posted on pump and meth.
Old Oct 3, 2007 | 05:45 AM
Big Boost's Avatar
You have a 2.3 right? This sounds like an awesome set-up. Could you please advise, what rpm you reach full boost in?
Maybe in 3rd and 4th gear?
Old Oct 3, 2007 | 07:02 AM
LT1runner's Avatar
Yes, I have a 2.3. I'll let you know when I get off work. I've developed a boost leak somewhere. I'll fix that and do a 3rd/4th gear pull to 20psi, and a 30psi.and let you know what PM I'm at when I reach 20psi/30psi. But this will be a raw and untuned figure before saturday. At what MPH would you like for me to start he pull(3rd/4th)?
Old Oct 3, 2007 | 03:42 PM
Big Boost's Avatar
Could you do something like this?
See this thread from Smogrunner:
https://www.evolutionm.net/forums/sh...d.php?t=222476
He has a very similar set-up to you, but is using the AMS 35R. I believe he started each run at a low rpm for each gear.
Old Oct 3, 2007 | 03:59 PM
EV0lved's Avatar
looks awesome
Old Oct 4, 2007 | 05:35 AM
LT1runner's Avatar
I updated MAFT Pro and have to retune just to drive it.
CmakEVOX
Midwest Region
Mar 17, 2009 08:42 PM
CmakEVOX
Jul 16, 2008 11:35 AM
iBOOST
For Sale - Cars For Sale
15
Feb 22, 2008 06:05 PM
Fernanmd
Nov 4, 2007 10:36 AM
