30 PSI with meth is TOO MUCH?
Old Sep 30, 2007 | 12:23 AM
Evo_Wanted's Avatar
well i dont know if 30 psi with meth is too much for a stock motor/head and head studs
these are the mods that I have
gt35r
hks 272/gear
880 injectors/255 fuel pump
EBC
FMIC
TBE
METH 50/50
Old Sep 30, 2007 | 12:39 AM
E VOL IX's Avatar
just look at my sig.. i didnt wanna push it past 27
Old Sep 30, 2007 | 12:41 AM
Wazvette's Avatar
gt35r
hks 272/gear
EBC
FMIC
TBE
METH 50/50
29psi with my past set up....3065 with meth
Old Sep 30, 2007 | 01:34 AM
EvOcHaRgeR's Avatar
I run 30.5psi with 35r and meth with stock block with no issues. Then again I only use it when I need too. No dyno where I live so no real numbers either
Old Sep 30, 2007 | 08:16 AM
evodrivesme's Avatar
i had all stock motor besides hks 272's and i ran 32psi on a 3076 and meth never had any problems and the highest knock i ever saw was 1 thats thanks to my awesome tuner nate from tpg!
Old Sep 30, 2007 | 08:18 AM
Rez90's Avatar
34psi with pump/meth. 2.3
Old Sep 30, 2007 | 08:25 AM
cij911's Avatar
The psi is not the real risk...Just make sure you have a great failsafe in case your meht injection fails....Plus you should have access to your turbo maps to determine optimal boost...
Old Sep 30, 2007 | 08:29 AM
NIevo's Avatar
I am running 29lbs with 100% meth and a M15 nozzle. On a 35R and stock block. Here are the results https://www.evolutionm.net/forums/sh...d.php?t=298619
Old Sep 30, 2007 | 03:59 PM
Luis@TTP's Avatar
get some headstuds and boost it man you have a big turbo use it lol high boost 30 psi 100% meth
Old Sep 30, 2007 | 08:30 PM
Blue Evo 8's Avatar
How much power did you make?
Old Sep 30, 2007 | 08:40 PM
cangriracing's Avatar
i thought changing the cams without changing the headstuds was a no no for the 8s
Old Sep 30, 2007 | 08:43 PM
Ultimate CC's Avatar
its not really the boost thats the issue its the amount of whp that you will be making...but yea the more boost the more power in most cases...whos doing the tuning???
Old Sep 30, 2007 | 08:46 PM
TTP Engineering's Avatar
Headstuds have nothing to do with cams.
Old Sep 30, 2007 | 08:47 PM
boostinpsi's Avatar
i think he is worried about stretching the stock studs and blowing a headgasket.
Old Sep 30, 2007 | 08:57 PM
Which has nothing to do with cams.
