BR3065R or AMS3076R
thanks sparky for the advise. I ready have a high flowing intercooler on the car and the high flow fuel pump. I have the HKS cams i heard they are pretty good for 550whp. I local tuner here in Oman suggests the Motec ita standalone plug and play ecu with alot more functions that the AEM one with logging, 3 map switchs, controls 8injectors and with antilag and launch control.
-Paul
i would stick with the stock ecu. You're not glued to one tuner with that because almost everyone is capable of producing a nice tune for you.
With the motec you wont have many choices of tuning and most likely the car wont be maximized.
The 3065 is basically a GT30r turbine (hotside) with a gt35R compressor (coldside).
The bigger compressor wheel produces more flow and the small turbine helps it spool fast but it also minimizes the potential output because of its turbine size. Thats why at the 30psi the bigger turbine of the GT35R takes over.
IIRC the HTA GT35R is basically your standard GT35R with a modified compressor wheel which increases the turbo's ability to provide airflow at lower turbine RPM's without sacrificing the overall top end ability. I believe the modification comes from FP but i could be wrong.
this modification ultimately ends up increasing the midrange power output of the turbo by a pretty substantial amount.
AMS 3076R. Not as fast of a spool as stock but I would guess atleast 400-500 sooner then the 3065. Makes it one of the best street turbos. I am planning on building a 2.3 in the future which should turn spool as quick as the stock one was. Also good for up to 500awhp with meth or race gas. Straight out drag and if you can live with the lag go 3065. Seems to make great power top end.
