TiAL 44MM Wastegate Question.
Old Oct 2, 2007 | 09:03 AM
Pure Playaer's Avatar
With my bushur racing turbo kit, in the 44mm wastegate, a 23 (or 24 w/e it is) pound wastegate spring was included, and for the longest time ive been running off of wastegate spring pressure as a boost controller.. Recently my tuner decided to swich out my spring for a smaller like 12 or 13 (im not sure the actual sizes, but a much smaller spring) pound spring.
Now this might be a ricey question but the way that the open wastegate sounded was extremly different, and alot louder, before the spring was changed.. am I just imagining this or is it actually happening? I really miss the loudness of the old spring, and I think I might have it reinstalled once my meth kit goes in.
Thanks alot
-Chris
Old Oct 2, 2007 | 09:23 AM
bmp
Old Oct 2, 2007 | 10:24 AM
Ted B's Avatar
I don't know about the change in sound, but there is no reason to use a spring any lighter than the minimum amount of boost one expects to run. As you denoted, if you can get a springs set for the boost level you want, there is no need for anything but the WG for boost control. It just doesn't get any simpler or better than that.
Old Oct 2, 2007 | 11:14 AM
Asmodeus6's Avatar
Agreed! Properly matching the spring rate to desired boost levels is the most rock solid way to control boost.
I could see using a slightly lighter spring if a you needed a range of adjustment due to pump/race maps etc.
Factoring the "sound" it produces into the decision process does indeed make you sound like an idiot. Come on guy. Stick to the program.
Old Oct 2, 2007 | 12:34 PM
TiALSport's Avatar
20.30psi is the highest spring pressure offered for the 44mm
it uses the big blue (13.05psi) and small blue (7.25psi) springs
you are probably imagining the noise
Old Oct 2, 2007 | 01:13 PM
Shearer's Avatar
^^^What he said.
Throw a big blue in and be done with it.
mrm95
Mar 16, 2015 08:59 PM
ryukinevo
19
Dec 7, 2013 11:42 PM
all4bspinnin
Jul 27, 2008 01:58 AM
TurboRSX04
Apr 28, 2008 08:44 AM
NITROHEAD
Lancer Aftermarket Forced Induction Tech
26
Feb 6, 2008 09:51 AM
