CBRD Radiator Install...
Old Oct 2, 2007 | 12:36 PM
CBRD's Avatar
hey everyone..
here are some pics of our lightweight radiators... being installed in a car we do a small sponsorship on...
cooling the car off...
stock radiator and hose position..
our radiator with fan being mounted..
tabs on backside... (we have a different style with smaller tabs that we use sometimes for cars that see greater vibration and abuse)
installed in the car
relocated neck
you can see that you cant use the stock air inlet piece with this radiator because of the relocated neck. We mainly built this rad to be used with tubular manifolds and where more turbo to radiator clearance is needed.
Superior cooling to stock, slightly larger tanks.... and lighter weight.....
cheers
cb
Old Oct 2, 2007 | 12:40 PM
Soon2BEVO's Avatar
What is the exact weight loss in lbs?
Old Oct 2, 2007 | 12:43 PM
Sap12687's Avatar
Could you PM me a price?
Old Oct 2, 2007 | 12:44 PM
Cali2MDevo8's Avatar
Registered User
DAMN Bazooka JOE!!! Pop the trunk Chad.............lol
jason
Old Oct 2, 2007 | 12:45 PM
Erik@MIL.SPEC's Avatar
I think there would be some of us interested in this radiator with the neck in the stock location (raises hand)
I would rather give my money to CBRD than let's say...Koyo
Old Oct 2, 2007 | 12:46 PM
AlohaEvo's Avatar
looks good, did we ever get how thick it was compared to stock in the other thread?
Old Oct 2, 2007 | 12:48 PM
CBRD's Avatar
stock is apprx 20lbs....
ours is 10 with the fan mounted.
cheers
cb
milo's Avatar
What are the cooling effeciency of the new radiator...........it better then stock.........does it hold more water/coolant?
Old Oct 2, 2007 | 12:50 PM
CBRD's Avatar
well,
I can certainly do that for you without a problem.
pm me if you are interested.
cb
Old Oct 2, 2007 | 12:51 PM
CBRD's Avatar
its identical to stock, but is moved slightly further forward to hug the condenser for a sealed fit.
it is a more efficient core, and with larger tanks, holds slightly more coolant/water!
cb
Old Oct 2, 2007 | 01:11 PM
dafunk630's Avatar
how much is it for the radiator shipped to 06106???
Old Oct 2, 2007 | 01:14 PM
CBRD's Avatar
please pm for pricing!
cb
Old Oct 2, 2007 | 01:24 PM
FloopyDisk's Avatar
That's pretty sick. Got some more specs on the cooling advantages?
Old Oct 2, 2007 | 02:08 PM
SickSilverNLow's Avatar
^^+1 on more specs.........looks good for sure.
Old Oct 2, 2007 | 02:58 PM
0100's Avatar
Veteran: Army
Yes(raises hand).
Is there any advantage for having the neck not in the stock spot?
+1 for more info on it's cooling efficiency vs stock.
