Who is using an ETS turbo kit?
^^Yeah 91 octane is crappier than 92 but 92 is still crap...
You should think about getting some Rod bolts....just for added safety. Any car pushing over 400whp should have the stock Rod Bolts upgraded. It costs around $250 or so but it saves thousands if you are gonna run a good amount of boost and drive hard. Good luck.
.You should think about getting some Rod bolts....just for added safety. Any car pushing over 400whp should have the stock Rod Bolts upgraded. It costs around $250 or so but it saves thousands if you are gonna run a good amount of boost and drive hard. Good luck.
I need to do this too, i am running like 23 psi on pump too, w/ supporting mods of course, but still.
Comp 280's
Fully Ported and Polished head
Supertec springs/retainers
AEM EMS
AEM Cam gears
AMS UICP
AMS FMIC
ETS LICP
ETS 35R
Denso 1000cc injectors
ACT Street clutch
Dual in tank Fuel pumps w/fuel regulators
AEM Meth, but those number are not on Meth, With meth it's more like 490 HP on 20lbs
AEM EMS
AEM Cam gears
AMS UICP
AMS FMIC
ETS LICP
ETS 35R
ACT Street clutch
.Well I visit the track occasionally, once a month probably, and do a good bit on the streets. My plan is: ARP head studs, rod bolts, ETS 3.5" downpipe back, ETS 3.5" FMIC, 870 or 1000cc injectors, meth, Comp Cams 280 w/ springs and retainers, clutch, mbc, fuel pump. I think thats it. What you think? I have talked it all over with Tom at ETS, so I feel pretty confident in the list.
It cost me around $250 or so with labor and parts. You don't have to pull the motor to install the rod bolts so guys over at English Racing did it in like an hour or two....
. Great investment if you are gonna be boost happy
Yeah man, get her done......Lucas charges like nothing to install these and gets them done quick if he has the rod bolts stock.
.Yeah man, get her done......Lucas charges like nothing to install these and gets them done quick if he has the rod bolts stock.
I know, I need to get down there and get those done, I have been meaning too, that might be my next investment actually...before cams...
.I would run the 1000cc injectors, I dont know much about Comp Cams but If I had another choice in cams i would run the GSCs. Get a EBC, such as AEM Tru-Boost cause its so convenient to change boost on the go. Get a wideband so the tuner can tune with it...AEM UEGO. I got some Cam Gears to go with my cam so the tuner can fine tune timing, should be good for a little bit of HP. Other than what i said your supporting mods looks great
. What meth are you gonna run...AEM, Snow, Aquamist...etc?
Yea I didn't put down any gauges on that list, but I plan on getting a Wideband along with a new boost gauge (psi), egt, and ot. As for the boost controller, I was thinking og going with the Hallman in ****-pit, I have heard great things about Hallman so I feel that it should be a good fit for me. The cams I had down to Comp and GSC S2's, but I leaning more towards the Comps due to a longer exhaust duration which should help to spool the turbo a little bit quicker than the GSC's, any thoughts on that? And I plan on going with a Snow meth kit
Id say call Greg up at GSC and talk it over w/ him first before going w/ the comp cams. I know the comps may be good, but GSC's are really good cams too.
Comp Cams are good cams but GSC's i believe is pretty good overall. The quality of their stuff is great. Just talk to Greg and ask them for some help on cam selection. They should be able to help you out.
Paul Nelson
ExtremeTurboSystems.com – WA
184
Jul 13, 2011 07:46 PM
ETS Michael
Apr 29, 2011 08:13 PM
SickSilverNLow
15
Aug 7, 2007 09:57 AM
